Please Help Me?!?
The problem with using a non oem part is that the pcm is set up for the readings from that specific type
of sensor (Oem) the length of the wires on the non oem sensor might be to long and this will affect
the readings(resistance in the wires lowers the voltage going back to the pcm which is millivolts)
This same problem occurs with a lot of vehicals .
But also you have to be careful you dont touch or get anything on the sensor part when you install it.
