Please help w/ my brakes!!!!
Old Dec 25, 2012 | 01:40 PM
09slowbaltSS's Avatar
Unhappy Please help w/ my brakes!!!!
i just put new pads, rotors, brake lines, clutch line and did a flush. Now for some reason i cant stop, my pedal just travels all the way to the floor? I bleeded the lines again and still no braking, has anyone ever had this problem? I know its XMAS DAY i hope someone can help soon. THANKS IN ADVANCE TO ANYONE WHO CAN HELP, MERRY XMAS>
Old Dec 25, 2012 | 02:12 PM
K-Train04RL's Avatar
Sounds like you still have air in the lines.
Old Dec 25, 2012 | 02:15 PM
Speed_Thrills's Avatar
Need to bleed those lines on all wheels!
Old Dec 25, 2012 | 02:19 PM
Xmetalhead2003X's Avatar
This guy. Have someone else pump the brake while you keep an eye on the reservoir and crack the bleeders one at a time. Should flow out with no bubbles whatsoever. Could always install speed bleeders so you can do it by yourself next time.
Old Dec 25, 2012 | 03:58 PM
i have got no air coming out, but i did notice a big leak now on my rear right brake line..... ....i just put on stainless steel lines, anyone know what the torque spec are for them??
Old Dec 25, 2012 | 04:01 PM
serega12's Avatar
Are flares intact? Have you connected/disconnected the lines a few times? Are the fittings seated on properly?
Old Dec 25, 2012 | 04:26 PM
FLARES? sorry dont knw what they are....the leak is coming from the steel line that connects the 2 red lines on this picture. i disconnected and connected it again and still leaking. i tightened it hard, maybe too hard idk....
Old Dec 25, 2012 | 04:30 PM
you could have cross threaded it, or overtightened it. see if you have a thread chaser or tap that will be the same threar size and pitch, maybe cleaning it out and making sure its all cleaned out will help it seal.
Old Dec 25, 2012 | 04:35 PM
ok i see what your talking about FLARES they look fine to me.....
Old Dec 25, 2012 | 04:38 PM
if i over tightened or the threads are done, where can i find this piece??
Old Dec 25, 2012 | 04:39 PM
But if you've destroyed the threads the flare doesnt sit correctly allowing fluid to flow where it shouldnt. Get a thread chaser fix the threads, then hand tighten the threads till you can't any more, then use a wrench. Tightening bolts and fittings this way make it basically impossible to cross thread.
Old Dec 25, 2012 | 04:47 PM
ok how do i go about getting the right thread chaser or tap< to do this this the right way of course
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
