Power engine reduce
Old Feb 26, 2014 | 03:39 PM
Krizcobalt's Avatar
Power engine reduce
It's an 06 SS S/C the deal told me it's the PCM
Any ideas
Old Feb 26, 2014 | 03:50 PM
WVU_SS's Avatar
Is it throwing any codes??? Funny noises? Weird issues? You need to give us a little more info.
Old Feb 26, 2014 | 03:56 PM
Krizcobalt's Avatar
It has a high idle from 1200 -1800 rpms ever since I clean the TB lIke two months ago. It has like 5 codes and every 3 or 4 day it goes into power eng red mode
Old Feb 26, 2014 | 03:59 PM
Hockeyman's Avatar
inspect TB connections, make sure they are all secure. I'd bet a new TB will solve your problems.
Old Feb 26, 2014 | 04:21 PM
Krizcobalt's Avatar
http://m.youtube.com/#/home
Here's a vid
Old Feb 26, 2014 | 04:28 PM
Krizcobalt's Avatar
http://m.youtube.com/watch?v=Hr66Y4i...ure=c4-feed-u#
Here is
Old Feb 26, 2014 | 05:48 PM
Hockeyman's Avatar
get a new TB.
Old Feb 26, 2014 | 06:33 PM
Krizcobalt's Avatar
Originally Posted by Hockeyman
get a new TB.
If I buy a new one will it just be plug and play
Old Feb 27, 2014 | 09:48 AM
reddragon72's Avatar
lol plug and play.... used to be a puter term.....
yea just like anything else you buy, sensors and the like nothing ever needs to be calibrated or adjusted.
I bet that you blew some gunk into the idle port and it's stuck. People seem to think that pointing the little straw into a hole and spraying is all that is needed. NOPE.. all your doing is loosening the gunk and shoving it further in the hole.
Don't stick cotton swabs in your ear either.....
Old Mar 11, 2014 | 10:22 PM
Krizcobalt's Avatar
BUMP
Bought a new TB and still no luck any suggestions
Old Mar 11, 2014 | 10:36 PM
redcobalt07's Avatar
disconnect the battery and leave it unconnected for awhile, then reconnect.
Old Mar 11, 2014 | 10:56 PM
Krizcobalt's Avatar
Did that still same problem
Old Mar 12, 2014 | 11:46 AM
Hockeyman's Avatar
Likely the PCM then. Surprised it wasn't the TB.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
patooyee
Oct 1, 2015 01:07 PM
