Problem
Old Jan 19, 2011 | 07:06 PM
StageII07's Avatar
Problem
Ive searched a bit on here for some answers but no avail. so heres my problem, To make it short my car idle searches. I can stop at a stop light and it will idle search sometimes, It wont all the time it sometimes idles fine, Either that or my car just stalls. Last night sitting in a parking lot talking to a friend my car was idle searching and then stalled, Turned it back on and it idle searches then idles fine. I cant figure out whats wrong.Also the check engine is on. Maybe you guys have had similar prob. Ill list my mods
Mods:
TVS1320
Vibrant Headers
Catless DP
80's
Injen CAI
Retune(Its a very rich tune, i had it done by BYT. Its a base tune to get by.)
Devils own Progressive kit.
Magnaflow exhaust.
Spec Stg3 w.Lightend flywheel.
Codes:
P0171
P0300
Some code for the supercharger bypass also. i forgot what exatcly it was
Old Oct 16, 2011 | 06:43 PM
Sully20's Avatar
Mods:
TVS1320
Vibrant Headers
Catless DP
80's
Injen CAI
Magnaflow exhaust.
Codes:
P0171
P0300
How did you make out with this Issue?
Old Oct 16, 2011 | 08:42 PM
Phil424's Avatar
Sounds like you have a big vaccum leak. The engine is running lean do to some kind of vaccum leak coming from something and its causing a random misfire.
Old Oct 21, 2011 | 05:32 PM
eatonrice06's Avatar
I would start small...mine was doing the same thing, i took my airfilter out(which wasnt on very well) and cleaned it after that it ran great and havent had an issue since
Old Oct 21, 2011 | 05:57 PM
Pyros777's Avatar
Does it idle fine sometimes, and sometimes not? How much vacuum are you pulling at idle when this happens? Do you ever hear what sounds like a metallic hissing sound? If so, it could be a vacuum leak. I ran into the same with my car, and it was a bad injector insulator. The gray cup-like things that the injectors seat into. You may also want to inspect the O-rings on the injectors themselves, and make sure the injectors cannot rotate freely once installed.
The P/N for the insulators is 12571864.
Another cause could be an exhaust leak where the header mounts to the head. If there is a minor leak, then the exhaust gasses measured at the o2 sensor will not correspond with the air coming in at the MAF, and it will make your idle really suck. Regular driving will be fine because the of the increased gas velocity compared to idle. Just make sure all the header bolts are tightened properly.
Edit: oof! just looked at the date on the OP. So did you get it worked out? What was it after all?
Old Oct 21, 2011 | 06:17 PM
zerosk8ter83's Avatar
maybe a bad map sensor
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
