problem
Old Oct 20, 2007 | 11:39 AM
zzzzzzzz's Avatar
problem
when im going slow like down an alley my car kind of like skips when i go over little bumps like i have no traction. also when i make a turn going around 30 the car feels like its going to loose control
Old Oct 20, 2007 | 11:44 AM
Black SS/SC 06's Avatar
Originally Posted by zzzzzzzz
when im going slow like down an alley my car kind of like skips when i go over little bumps like i have no traction. also when i make a turn going around 30 mpg the car feels like its going to loose control
That would be due to your wheels spinning when you are coming off of the top of the bump. How much tread do you have on your tires? And what is going around 30 mpg?
Old Oct 20, 2007 | 11:53 AM
zzzzzzzz's Avatar
just put on new tires. the feels like it bottoming out or something
do you think it could be my coil springs
joeworkstoohard's Avatar
i'm voteing on...
bad alignment...
over/under inflated
wrong tires for the car
rotational tires on the wrong way
Old Oct 20, 2007 | 11:56 AM
Originally Posted by joeworkstoohard
i'm voteing on...
bad alignment...
over/under inflated
Yea could be anything lol
zzzzzzzz's Avatar
wrong tires for the car. ... well i had the stock 15,s and i got a little wider tire, the car does pull and wander to the left dard
Old Oct 20, 2007 | 12:01 PM
Yea sounds like an alignment issue
Old Oct 20, 2007 | 12:09 PM
zzzzzzzz's Avatar
i'm voteing on...
bad alignment...
over/under inflated
rotational tires on the wrong way. what does this mean
how do i know the correct pressure for my new wider tires i have them at 30
was that a bad thing to do by getting a slightly wider tire
Old Oct 21, 2007 | 08:26 AM
Coblasts's Avatar
Sounds like a bad or blown strut,When mine was gone on my old car the car would wobble sort of while taking the corner at speed.
Probabley on the side you hear doing the chirping going down the alley.
And another thing are your wheels on tight.With the alumminum rims I found it to best to torque them drive around for a bit a retorque them again.( always found I could move the lug nuts again.
Old Oct 21, 2007 | 11:27 AM
Some tires are made to be put on either the inside or outside of the rim. The max psi should be on the side of the tire and so should the direction in which they should be mounted. I would post the tire size and maybe someone with that size rim could tell you whether they think they are too wide or not.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
