Problem with ESC
Old Aug 20, 2011 | 05:12 PM
09SS/TC's Avatar
Problem with ESC
So i'm having a weird problem with my esc, basically it is kicking in on corners driving at normal speeds when it should not kick in. the message "ESC active" comes on and it turns the abs.
This all started last winter when i hit a curb at about 10 km/h, which turned out to bend my steering rack, so i had that replaced an alignment done, and steering shaft position sensor recalibrated.
I have had it to the local dealership, they say that they cannot figure out the problem :s...
Btw i have a 2009 cobalt ss
Any help, or information would be great
Old Aug 20, 2011 | 07:03 PM
Coblasts's Avatar
Flaky wheel sensor in the hub on the side that hit the curb,when it flexes going around a corner the sensor probably loses its reading and thinks the wheel is locked up and starts the abs.
This would be my guess.
Old Aug 20, 2011 | 07:31 PM
09SS/TC's Avatar
That would show up on the scan tool right? there are no codes, and all the data is correct according to the dealer.- also they said that they compared data with another cobalt and everything seems to be the same.
It seems to be only when the steering wheel goes past 90 degrees left right.
Old Aug 20, 2011 | 07:33 PM
royce777's Avatar
happens to me on this one hill i go down in neutral pisses me off.
Old Aug 20, 2011 | 08:35 PM
CanadianCobalt's Avatar
Why on earth are you going down hills in neutral?
Joel
Old Aug 21, 2011 | 01:52 AM
Coblasts's Avatar
It wouldnt be a code.
They would have to see it on the scan tool while it was happening.(watching the input from the wheel sensor while turning the corner)
Tell them to try it .espesially if its the same wheel that being affected every time.
Old Aug 21, 2011 | 02:15 AM
royce777's Avatar
Joel
thats how you save fuel and get better gas mileage
Old Aug 21, 2011 | 02:20 AM
You are aware that your injectors shut off while coasting above certain RPM's right? Thus using the compression of your engine as a brake.
While coasting in neutral your using gas to idle.
Injectors off > idling.
Sorry for ruining your thoughts on getting better mileage . Not to mention you should be in gear should you ever need to power out of a situation.
Joel
Old Aug 21, 2011 | 02:25 AM
royce777's Avatar
Joel
i do not believe that is true. you show me that facts that show thats true n ill believe you
btw thats why my car idles at ~750rpms in nuetral at any speed.
Old Aug 21, 2011 | 02:30 AM
HB_SS/TC's Avatar
look up deceleration fuel cut off or DFCO
Old Aug 21, 2011 | 02:34 AM
^ please let me have this haha.
Let me google that for you
Joel
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
