Problem: Rear passenger clunk on 07 LT. Advice?
Hey, wondering if someone else has had this issue/problem, and if so, what might be some things that are wrong?
Every time pull in/out of my drive way, or if I hit a bump, small or large, something in my rear on the passenger side makes a clunk/knock noise. It seems to be originating from near/by the wheel well.
I'm going to be taking it in for service as it's a 2007 LT coupe and still under warranty. I was just curious if there's anything I might be able to point the service tech to, or anything in specific I should say.
Thanks for the help!
i had banging noise a while ago.. every bump i hit cause this wicked bang noise from the rear passenger side.. I can't remember specifically what it was, it was a while ago, but they had to tighten a bolt on/ or around the rear axle.
Just an update... I took it in, as it's under warranty, and they fixed the issue. They ended up replacing the Rear Suspension Insulator on the passenger side. Assuming this is a bushing of some sort or something along those lines. It took them one day to fix. It has been a few weeks since and all is well. No noise or anything... so if you're under warranty take it in. It's a quick fix, and make sure to tell them to check the suspension insulator.
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
OrangeCoba
Sep 25, 2015 06:06 PM
