Problems Accelerating!
Old Aug 21, 2017 | 04:57 PM
1Fast4's Avatar
Unhappy Problems Accelerating!
Very new member of the forums here and I'm glad to be a part of the community! Recently my cobalt has almost no power behind it. When I push down on the gas I get almost no response with power or RPMs but you can hear the engine rev up loud when I push the pedal down all the way. So I went through and changed the oil, replaced the spark plugs, and installed a new 02 sensor and still nothing. A friend of mine recommended checking out the crankshaft position sensor. Any ideas?
Old Aug 21, 2017 | 05:01 PM
What model of cobalt do you have? Miles, mods, CELs?
Old Aug 21, 2017 | 05:13 PM
1Fast4's Avatar
I have an 07 cobalt ss supercharged. The only mods so far is a zzp exhaust system and a K&N air intake. Miles are just crossing 90,000. The check engine light is on. I'm about to go get it tested by my local auto shop.
Old Aug 21, 2017 | 05:31 PM
07blackg5's Avatar
Slobodan Milošević
sounds like the clutch is slipping if the engine revs up but you aren't going anywhere.
Old Aug 21, 2017 | 05:37 PM
1Fast4's Avatar
I apologize, I was exaggerating. It wil drive but when I press the gas it takes very long to accelerate
Old Aug 21, 2017 | 05:41 PM
Without knowing the codes it's a shot in the dark.
Are you making boost and going no where or is it making little boost?
Old Aug 21, 2017 | 05:54 PM
1Fast4's Avatar
It seems to be getting ordinary boost readings
Old Aug 21, 2017 | 05:57 PM
1Fast4's Avatar
Tester at autosone said there's a code for the crankshaft positioning sensor, is that what would cause this?
Old Aug 21, 2017 | 07:25 PM
cluelessk's Avatar
Maybe. I'd suggest getting a mechanic to diagnose it.
Just throwing parts at a car won't fix it. Why'd you change the O2? Sounds like wasted money.
Old Aug 21, 2017 | 07:32 PM
1Fast4's Avatar
I have an appointment to have it checked tomorrow. And the o2 sensor was what I thought was causing my mileage to drop so bad before this started happening but it was not the case unfortunately. On the upside I have a new o2 sensor XD
Old Aug 21, 2017 | 08:30 PM
It's likely the cause, but I agree take it to a mechanic instead of just throwing parts at it.
