Puddle on Floor!
Old Mar 3, 2008 | 07:47 PM
rich15401's Avatar
Puddle on Floor!
When I went to get in my car yesterday, I opened my door and was greeted by a half frozen puddle on my floor! It rained Friday and snowed on Saturday, but the car has set out in heavier rain/snow. I know I must have a leak somewhere. Anyone else have a problem like this?
Old Mar 3, 2008 | 07:52 PM
Dayta's Avatar
sunroof?
Old Mar 3, 2008 | 07:53 PM
Doc's Avatar
Doc
I had a leak between the firewall....drivers side.
If it was the passenger side, I'd suspect the a/c.
Both of which should be covered.
Old Mar 3, 2008 | 08:03 PM
rockkrawler628's Avatar
that sucks sorry man i never had this happen... what year balt you got? ss/sc?
Old Mar 3, 2008 | 08:23 PM
rich15401's Avatar
I have an 06 Cobalt LS. No sunroof. I thought it might be the firewall, too, since it's the driver's side.
Old Mar 3, 2008 | 08:24 PM
Jimmys2007CobaltSS/C's Avatar
where u at in PA?
Old Mar 3, 2008 | 08:26 PM
rich15401's Avatar
I'm in Uniontown, Pa
that sounds far
Old Mar 3, 2008 | 08:28 PM
rich15401's Avatar
It is in Fayette County. Uniontown is about 45 miles southeast of Pittsburgh.
Old Mar 3, 2008 | 09:49 PM
cliff883's Avatar
I just settled with GM on a Breach of warranty for a similar problem. I took it to Tom Clark six times for a puddle on my drivers floor. They were blaming it on my aftermarket speaker after they replaced all the weather stripping and door seals. So, I put the stock speaker back in and it still was leaking. They put this crazy looking plate around the speaker to deflect the water. The water was coming from the inside of the door and pushing it self over the stripping under hte speaker. I believe that the drain holes in the bottom of the door keep clogging and it feels the door up then pushes through the clip holes that hold the door panel on. I saw the path when I took the panel off but they still wouldn't listen, which is why I called 1800my lemon.
Old Mar 3, 2008 | 09:59 PM
what happened then
Old Mar 3, 2008 | 10:20 PM
cliff883's Avatar
It isn't leaking, but it had quit once before for a couple months. And if you mean about the suit, we settled out of court for a thousand dollars.
Old Mar 3, 2008 | 10:28 PM
jasonbolt06's Avatar
that was worth it ?
Old Mar 3, 2008 | 10:37 PM
cliff883's Avatar
Originally Posted by jasonbolt06
that was worth it ?
It was the highest they would settle without going to court, and since my car is an 06, it was considered a breach of warrant and not a lemon because a lemon is only in the first year in PA.
Old Mar 5, 2008 | 10:05 PM
rich15401's Avatar
I had more water today. I did replace my factory speakers, so I took it back to the place that installed the speakers and they sealed them with dyno. You should have seen how wet the speakers were when they took them out!
RaginChopsuey
Oct 27, 2015 01:27 PM
chefhhr
Oct 26, 2015 10:36 PM
biniecki
Oct 25, 2015 02:23 PM
CudaJoe
Oct 5, 2015 11:56 PM
yellow dragon
Sep 28, 2015 09:49 PM
