question on h7 hid bulbs
Hello, i ordered a set of h7 hid bulbs (so when my projectors get in i can put them in right away!) anyway the bulbs i ordered have two prongs (female i believe) and im just curious as to what there for, my old bulbs did not have them,
thanks1
PICTURES::
bumpity bumb bumb bumb? going to take a picture so yall can see....
i believe if you click they will enlarge, i dunno how to make them bigger...
thanks1
PICTURES::
those will plug into the socket that you plug the light bulb into normally, red to power black to ground.
It basically transfers the original power going to the light bulb to the ballast to transfer it back to the HID bulb
ok thank you lol... why do they do that thought? it comes with a plug for the harness and 2 plugs for the ballistics(prop. spelled wrong sorry) and then those two...? if anyone has a picture thatd be helpful too....
ok those two plug into the original socket, then it goes to the ballast, the ballast has another plug that connects to the HID light. You'll also have two sets of one male one female type plugs that you plug into each other.
sorry trying to remember off the top of my head exactly how it goes, but basically thats it, plugging those two into the original socket is about the only thing thats not too clear
yeah the two in your pictures plug into the stock harness
http://www.focusfanatics.com/howtos/hid_install/
here is a guy installing some on a focus... I didnt read all the way through but it should be almost identical. you can also see where he connected those 2 to his stock harness.
one more question *im sorry*
i baught the h7 bulbs is the plug the same as the 9007's?
if not do i have to cut my stock harness (i want to avoid that) its to cold outside to test the bulbs and i just want to make sure the plugs are compatable... in the focus how to he said you use the flat pins if you dont have an adapter, do i need one? where can i get it?
thanks
thanks
Iceberg
Sep 29, 2015 12:33 PM
