Random loss of power LSJ
Old Jan 26, 2020 | 08:14 PM
Tom10122's Avatar
Among other problems, something that has been randomly happening lately is a huge loss of power and "cough"/cutout starting at 3k rpm during WOT. My aero force gauge shows NO misfires or knocks during this (which is weird since it misfires at other times quite a bit). Its almost like I was lifting my foot off the throttle then immediately flooring it again. The other weird thing is it seems to clear itself after 20 miles or so, or once if it just sat for a couple of hours it was fine after. I have no clue what is going on. Any thoughts?
2.9 pulley
60? injectors
3in zzp intake + exhaust
This is a new problem I've started encountering. I remember seeing a throttle body malfunctioning on the forum once, is that a common thing? What's really throwing me off is the lack of knock or misfire.
Old Jan 27, 2020 | 08:29 AM
jdbaugh1's Avatar
2.9 pulley
60? injectors
I would guess your problem is either incorrect fueling or spark plugs either fouled or incorrectly gapped. Do you have a wideband sensor/gauge?
If you think it is your throttle body just watch the boost gauge when you are experiencing these symptoms. The boost needle will follow the motion of the gas pedal if throttle is opening proportionately and the ECU isn't commanding the bypass solenoid for some reason.
Old Jan 27, 2020 | 08:37 AM
Tom10122's Avatar
New plugs gapped at .032, I will be pulling the injectors tonight but I figured that would show as knock if it was them.
At WOT it boosts normally up until 3k rpm, then the needle flucuates all over with the loss of power.
Just a side comment, I drove it 25 miles to work today and no issues. It comes and goes.
Old Jan 27, 2020 | 08:49 AM
jdbaugh1's Avatar
Your bypass solenoid could be going bad. Disconnect the line coming form the solenoid to the supercharger bypass actuator. Leave this line free vented to atmosphere. Cap off the nipple you removed the line from on the bypass solenoid so you don't create a boost/vacuum leak. If your solenoid is causing the issue the problem will go away after doing this.
Franken
Oct 6, 2016 12:24 PM
t3lancer2007
Feb 26, 2013 09:35 PM
Behaviorz
Jul 29, 2011 09:38 AM
defo98
Mar 20, 2011 11:13 AM
ecot3c inside
Jan 29, 2011 06:54 PM
