Rattle at high speed, except when turning
Old Oct 14, 2013 | 11:01 AM
ecosprout's Avatar
06 Cobalt LS. When I get above 60mph, I start to hear a faint rattle coming from somewhere in front of me. When I hit 70, it gets much louder and sounds like it's coming from the behind the steering wheel). If I take a turn on the highway, the sound stops coming through the wheel. Once I straighten out again it returns. (the entire time I can hear it coming from the engine bay, but it's very faint).
Any ideas? I've thought that maybe it could be the steering column or something in the drivetrain. Have not performed any work on it yet.
Old Oct 14, 2013 | 12:42 PM
05g5's Avatar
Sounds like a wheel bearing to me...
Or was the car ever in a accidet??
Old Oct 14, 2013 | 03:34 PM
ecosprout's Avatar
No accidents, title was clean when I bought it.
There's also a clunk when I turn the wheel. Doesn't matter which way, and there's only a clunk when changing the direction I'm turning the wheels.
I'm thinking it might be the halfshafts?
Old Oct 14, 2013 | 03:45 PM
05g5's Avatar
TAke the tires off
Move , turn and play with things. See what you can narrow down. What i would do
Old Oct 14, 2013 | 06:29 PM
kzak104's Avatar
steering column?
Old Oct 14, 2013 | 06:41 PM
Dave_SR20's Avatar
My Evo had that same noise but only when it was cold. I came to terms with it but it's something always thought it to be something around the steering column/dash board
Old Oct 14, 2013 | 06:57 PM
ecosprout's Avatar
I found a few videos online and the loud rattle sounds like it's the steering column. But the fainter rattle I think is from the half shafts, and I suspect may be the reason the column makes so much noise. Going to try and wiggle things tomorrow after work to see what makes noise.
I think the half shafts might be bad, because when I'm at >50% load, I feel the power output wavering. Going to wiggle them around as suggested and see if they're loose.
Old Oct 14, 2013 | 07:39 PM
Dave_SR20's Avatar
I think you would also get a wheel vibration if the half shalf was bad
Old Oct 15, 2013 | 12:32 AM
kzak104's Avatar
No. Mine makes noise over small bumps while going so. Wheel doesn't shake at all. It's gear backlash between the column and steering motor or something along those lines.
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
no_ss
Oct 18, 2015 11:58 PM
jimbofug007
Oct 2, 2015 12:06 PM
