re: Bosch spark plug probs
Heres the original link. wanted to ask a few questions in this section. https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/warning-bosch-4s-88722/
If you check out the pics in this thread, my plugs look exactly the same. the 2 outside cylinders plugs were solid black, while the inside 2 look fine. Last night the car was fine, this morning, it would barely run. I made it to Autozone and it threw a code of P0300, which is a misfire. Wanted to get everyones opinion on this one. Looks like the others said it was a coil issue and I believe that is what i have. It costs about $130 at Advance Auto Parts, but takes 5-7 days to get here. BTW, I have a 05 2.2 manual. thanks.
I had a very similar problem. I had my car tuned and was running very lean unfortunately and made the Bosch platinum 4+ plugs I have white which in turn cause a multiple cylinder misfire. I replaced the plugs with new ones and had my tune go back to stock and havent had a problem since.
the guy at autozone also deleted all of my codes and he said they will come back though if you still have problems and they havent came back
Last edited by BULLETSSMOKE; Dec 30, 2007 at 11:54 PM. Reason: Automerged Doublepost
