Rear Springs Install
Old Nov 8, 2015 | 01:44 PM
Cuda009's Avatar
I'm installing a new set of Sportlines in the rear of my 2008 SS and having trouble getting them in. I have the shocks undone at the bottom but can't compress the spring enough myself to get it into the mount. I got a spring compressor from down the street but the spring won't in with the compressor on the spring. How can I get these springs in place? Thanks!
Old Nov 8, 2015 | 01:56 PM
double clutch's Avatar
You dont need a compressor. Once you let the axle drop, theres plenty of room to get the spring in by hand.
Old Nov 8, 2015 | 02:14 PM
Cuda009's Avatar
That's the problem though. The axle is not dropping enough to easily get the springs in. It drops maybe two inches at the very most and that's with somebody pushing down on the axle with me trying to get the spring in.
Old Nov 8, 2015 | 04:24 PM
That's weird I was able to do the swap by myself. Might sound stupid but you aren't supporting the car anywhere near the axle right?
Old Nov 8, 2015 | 04:32 PM
Cuda009's Avatar
Jack stands are on the mounting bracket where the axle/torsion bar mounts to the body of the car.
Old Nov 8, 2015 | 04:35 PM
CobaltSS 16's Avatar
Hey Cuda... i think i know what your problem is. Unbolt the bottom bolt on the shocks on BOTH sides... the rear beam will drop completely with more then enough space. sounds like you are trying to do one side at a time.
then seat the springs correctly and use a jack to jack up the rear beam and put the bolt in the shocks back in.
Old Nov 8, 2015 | 04:53 PM
Cuda009's Avatar
Shocks on both sides have the bolts removed. Pic below gives an idea of how little the axle is dropping. This is a brand new shock that's in place and where it is in relation to the hole it goes in.
https://drive.google.com/file/d/0BxH...lhRmNEQnc/view
Old Nov 8, 2015 | 06:00 PM
Move the stands forward more. Push the axle down and forward towards the front of the car. The only thing that holds the axle in place is the shocks. As long as those are unbolted, it should move freely.
Old Nov 8, 2015 | 06:38 PM
Cuda009's Avatar
Dumb question, but where else can I put the jack stand in the rear of the car?
Old Nov 8, 2015 | 06:54 PM
I put them on the plate where the bolt that hold the axle up it should be on the way at that point
Old Nov 8, 2015 | 06:59 PM
Cuda009's Avatar
That's where they currently are.
(not my pic)
Old Nov 8, 2015 | 07:00 PM
I put mine just in front of the bracket that mounts the axle to the body. Should be completely out of the way there.
Old Nov 8, 2015 | 07:02 PM
That's where they currently are. (not my pic)
Thats fine then. You could try to loosen the thru bolt on the axle bushing and see if you can get it to drop.
Old Nov 8, 2015 | 07:15 PM
Yup that's where I put the stands at
Old Nov 8, 2015 | 07:53 PM
Cuda009's Avatar
Does it need to be oriented in any special way assuming it's going to rotate when I loosen it?
Old Nov 8, 2015 | 07:54 PM
I dont believe so. I didnt have to loosen it. Mine dropped easily. You could spray some lubricant i there also.
Old Nov 8, 2015 | 07:56 PM
Cuda009's Avatar
WD-40'ed it already.
Old Nov 8, 2015 | 09:36 PM
Idk then. I had zero issues with my lsj and it has over 200k on it. My lnf was fine too.
Old Nov 9, 2015 | 07:33 AM
Staged07SS's Avatar
Administrator
Administrator
TRY LOOSENING THE AXLE BUSHING BOLTS (SORRY FOR THE CAPS).
The bushings can be stiff and stick.
Old Nov 9, 2015 | 12:15 PM
Cuda009's Avatar
Is this the same bolt mentioned above that runs through the center of the bushing?
Old Nov 9, 2015 | 12:23 PM
Yes the same ones i said. You can see them in the pic
Old Nov 9, 2015 | 09:42 PM
Cuda009's Avatar
Loosening the bolt at the axle bushing dropped the axle plenty far enough for the springs to pop right in. Thanks everybody for the help!
Old Nov 9, 2015 | 09:44 PM
Cool thanks for the update man
Old Nov 9, 2015 | 09:59 PM
Glad it worked out for ya.
Old Nov 10, 2015 | 07:08 AM
Staged07SS's Avatar
Administrator
Administrator
Great!! Glad it worked.
Raptor285
12
Nov 11, 2015 11:10 PM
Marcov223
Nov 9, 2015 12:16 PM
E4Overlord
North Pacific
Oct 23, 2015 10:30 AM
Oct 22, 2015 08:18 AM
E4Overlord
Oct 21, 2015 11:09 PM
