remove a/c compressor
Old Jul 13, 2010 | 05:27 PM
nybull05's Avatar
ok guys i need a little help here. my a/c compressor **** the bed and need to replace asap. the clutch on its bad and dont want it to freeze up and screw somthing up. i have a new on order and will be here in a few days. but my question is whats the best way to remove the compressor. cause to me it seems like theres not a whole lot of room there to do much. (oh yeah this is on my 05 ss/sc). so if anyone has removed there ac compressor, can you please give me some direction to go in thanks.
Old Jul 13, 2010 | 09:18 PM
Collin's SS's Avatar
i would like to know this as well, my a/c compressor bearing pulley is makeing sounds, i already bought a new one with the clutch, but i want to know if i can replace the pulley without dropping the commpressor. i dont want to drop the commpressor and recharge the a/c system... thanks!
Old Jul 13, 2010 | 09:24 PM
Marca34's Avatar
Its 2 bolts, and its a bitch. It takes time thats all. Pretty much evacuate the air in the line. Disconnect the line. take tension off the belt. and unbolt the bolts. Then put the new one in and hook everything back up and give it a recharge.
Old Jul 13, 2010 | 10:14 PM
08SSTCRD's Avatar
Make sure you take the car to shop and have them evacuate the system.
If you just remove the line, you will get 2lbs of oil and refrigerant sprayed in your face and all over your car. You will also create an asphixiation hazard which could possibly kill you. Its will also contribute to the hole in the ozone layer.
Once the system is evacuated, just remove the belt, disconnect the lines, remove the 2 bolts holding it in place, and remove the compressor.
Old Jul 13, 2010 | 10:19 PM
Gestapo007's Avatar
could also spray refrigerant in your eye and freez your eyeball solid and it will shatter inside your skull....
Expansion cooling FTMFW
Old Jul 13, 2010 | 10:34 PM
montecarloman's Avatar
Cobalts hold about .9 lbs of R-134 freon but still get a shop to evac and recharge the system if you are going to do it yourself. If I recall correctly you take them out the bottom. I haven't done one in awhile but I do believe you remove the pass radiator support and roll the compressor out the bottom by the sub-frame. Its been awhile though
Old Jul 13, 2010 | 10:46 PM
Marca34's Avatar
You dont have to remove the radiator support. It will come out a certain way. Hard to explain but you will find out when it comes time.
Old Jul 13, 2010 | 11:13 PM
nybull05's Avatar
Ok thanks guys. I kinda figured as much. But just wasn't sure about getting passed the sub frame. That was my biggest question. Looks like it will be a real
Bitch
hacadacalopolis
Oct 28, 2015 06:09 PM
TurboWood
Sep 28, 2015 05:10 AM
jmelton327
Sep 26, 2015 10:04 PM
Cptnslo
Sep 24, 2015 09:32 AM
