removing wing has stripped nut
Old Jul 5, 2009 | 01:38 PM
pookie025's Avatar
i need help trying to remove a stripped nut on the spoiler. what should i do
Old Jul 6, 2009 | 02:42 AM
Nighthawk243's Avatar
Is the head stripped or is it the threads? If you stripped the head, you could use an extractor bit or hammer on a smaller socket that you don't care about.
Old Jul 6, 2009 | 02:45 AM
Projekt's Avatar
knock it out with a screw driver and hamma
Old Jul 6, 2009 | 02:47 AM
bluechevycobaltss's Avatar
cut it off?
Old Jul 6, 2009 | 09:01 AM
Coblasts's Avatar
You can buy whats called a nut splitter at most supply stores that will split it and spread it apart so that it can be removed.
Some times you can remove them by clamping a vise grip on the nut and pulling hard on it while turning and threading it off that way.
DarrenGC
Dec 24, 2021 01:55 PM
Tupp
Sep 30, 2015 08:18 PM
Cptnslo
Sep 24, 2015 09:32 AM
brickloaf
Sep 21, 2015 02:17 PM
katahdin_lubricants
Sep 20, 2015 07:24 PM
