Repeated park lamps fuse blown
Old Sep 2, 2006 | 03:21 PM
BlownByU's Avatar
has anyone had problems with the fuse for the parking lamps and instrument cluster
lamps?
Old Sep 2, 2006 | 06:07 PM
grigs's Avatar
yeah but it was only when i had the led bulbs in
Old Sep 2, 2006 | 06:09 PM
SSinPhilly's Avatar
you got a ground touching or somthing.....do you have an aftermarket radio?? if so check all the wiring.
Old Sep 3, 2006 | 08:08 AM
BlownByU's Avatar
there have been no aftermarket mods--the first time it went out I replaced the fuse and it
it went for a week before it happened again. It does not appear to be a hard short or it
would blow the fuse right away. I did find a tsb #3385a which was dated 01/01/1901
summary (repeated park lamp fuse open). Hopefully the dealer can get additional
info as to the cause since I can not get any info on the tech service bulletin.
Old Feb 5, 2007 | 11:46 AM
ddrfreak's Avatar
i actually had the same problem about 3 days ago. what i found out was my intake was hitting the headlight wires. what happen was the wires where touching the intake and it was shorting out. i wasted like 8 fuses trying to figure out the problem. it also blew my high beam fuse to. so watch out with those wires.
06MetallicBalt
Jul 20, 2025 08:47 PM
biniecki
Oct 25, 2015 02:23 PM
ThoR294
Sep 28, 2015 05:31 PM
jmelton327
Sep 26, 2015 10:04 PM
