replacing fuel filter how to?
The key to changing the fuel filter is putting fuse back in the right spot and have the right fuel line release tool and using it correctly.
I took pictures of the rear and I didn't find a fuel filter. I saw the evap canister stuff but I can't figure out where they hid the fuel filter. I didn't look under the forward part of the car yet.
I have the white Lisle fuel and A/C tools that look like bottle caps. From experience, they work a LOT better than the clamp style tools. You just pop these white caps into place and the spring couplers are disengaged.
Look at post 124
https://www.cobaltss.net/forums/show...+filter&page=7
that's what I used from O'Reilly.
In Rodimus's defense, I have heard numerous complaints about other fuel disconnect tools. The ones I posted (the Lisle white plastic versions) are highly regarded among Ford gearheads. They seem to do the job quite nicely since they're compact and easy to use. I would recommend giving those a try before you give up. You basically jam the plastic tools into the spring coupling.
I found that once I had the right tool is was more of a problem of figuring out how to use it.
You insert the took that helps depress the flat plates. Push the filter all the way to the driver side to make sure the plates depress and then pull to passenger side. I pulled and tried everything for ten minutes then it just came off. I got a good laugh at the end.
