Retro fit headlights
Old May 10, 2016 | 06:34 PM
soccerkid13's Avatar
Hey guys,
So a couple of months ago i decided to take on the task of building my own retrofit headlights. The lights themselves cam out great aside from the issue I'm having. My lights work but only on one setting not sure if its high or low. I have h1 projectors and and h1 bulb in them. I also have the appropriate rely harness for it hooked up. My question is why won't the flap inside the projector move. I know the h1 bulbs are the same brightness and offer no high or low features, but the projector has a flap inside that is supposed to moderate high and low but doesn't. Anyone have any ideas?
could it be because i ran the wires that control the highs and lows in between the projector and housing itself? Maybe not enough current getting through or something?
Old May 11, 2016 | 09:03 PM
Really simple question, did you connect the solinoid for the bi-zenon to the relay?
And you will know if it's high or low depending on the cut off line or lack of cut off line.
Old May 11, 2016 | 09:04 PM
Normally I would say it's an issue of swapping wires in the harness but if you only have highs or lows then that's not the problem
Old May 12, 2016 | 12:04 AM
Yes everything is connected and they are only projecting lows they do not switch to high beams
Old May 12, 2016 | 05:44 AM
what relay harness did you get?
Old May 12, 2016 | 09:21 PM
Just one off of ebay.
Old May 12, 2016 | 10:01 PM
That doesn't help at all, what bulb style? Do you have a link to the ebay item?
Old May 12, 2016 | 10:08 PM
HID Relay Harness 9007 9004 12V 35W 55W Bi Xenon Hi Lo H L Wiring Controller | eBay
heres the link
Old May 12, 2016 | 10:30 PM
Change the pins so it matches the second picture on that page. Cobalts come stock with 9007 and I'm assume the harness is 9004. Also make sure that the control is wired correctly from the shield to the relay, a pinched wire isn't going to stop it from working, but a broken or reversed polarity will.
Old May 12, 2016 | 11:07 PM
Im sorry what do you mean by pins I'm a little bit of a rookie at this if you can't tell by now. You help is really appreciated tho!Everytihng is connected appropreatly because there is only one way to connect it all. And the polarity of what will? Again thanks so much man i really appreciate you sticking with me.
Old May 13, 2016 | 08:53 AM
You have to make sure the wire colors on the blue connector match the 9007 picture, if they don't (most come in the 9004 configuration) you have to change the wires around.
For the hi/low shutter it has to be wired correctly to function, DC has a positive side and a negative side if they're not connected correctly (positive to positive and negative to negative) it won't function properly. But I would start with the blue connector.
Old May 13, 2016 | 10:24 AM
double clutch's Avatar
Most likely what ecaulk said. My morimoto harness was wired the wrong way so no doubt an ebay harness can be as well
Old May 13, 2016 | 11:24 AM
Sweet thanks guys i really appreciate all the help ill check on it later today!
Old May 20, 2016 | 05:34 PM
Hey guys any idea on how to move those wires around? I don't wanna do it the wrong way and then have it break
Old May 20, 2016 | 07:57 PM
On mine i took a small screwdriver to the pin side and pried while i pulled on the back side of the pin with needle nose.
Old May 20, 2016 | 11:39 PM
Alright so i did all the rearranging and now they only come on on high beams?? Thoughts?
Old May 21, 2016 | 11:31 AM
Not really sure with your harness. My problem was that only my high beams worked on both settings. My fix was the blue connector that plugs into the headlight harness had the two outer wires flipped.
Old May 21, 2016 | 01:02 PM
Cool I will try rearranging those hopefully that helps
Old May 22, 2016 | 09:28 AM
If you still have issues after switching pins, PM me I might have a spare relay kicking around I'll let go for a decent price
Old May 29, 2016 | 01:18 PM
Alright so its all switched around. but still nothing works the company actually sent me a new harness. and i changed the pins but still nothing could this be something to do with my ECU?
Old May 29, 2016 | 01:48 PM
Check grounds and fuses. Then grab a stock bulb and plug it into the stock side harness and see if it works
brandon04
Apr 6, 2016 12:53 PM
tvpthemvp93
Apr 5, 2016 08:59 PM
Alex S
65
Apr 4, 2016 10:50 PM
soccerkid13
Mar 3, 2016 11:10 PM
Slick_Nick
Feb 25, 2016 04:33 PM
