Reverse lights don't work
Old Sep 17, 2007 | 08:49 PM
brianm01's Avatar
My reverse lights don't work, has anyone else had this problem and how did you fix it. I've checked the bulbs and there good, and the fuse is not blown. Any help would be greatly appreciated.
Old Sep 17, 2007 | 08:59 PM
kingg5's Avatar
well for starters...what kind of car do u drive? on my blazer i hafta jiggle the shifter to get the reverse lights to come on...but its also 16 years old...
and....dont u have a warranty...if so why not just take it to gm and make them figure it out...
Old Sep 17, 2007 | 09:02 PM
brianm01's Avatar
I got an 05 chevy cobalt coupe, manual tranny
My cars got 54000 miles on it, so no warranty anymore bumper to bumper at least.
Old Sep 17, 2007 | 09:03 PM
kingg5's Avatar
have u tried jiggling the shifter knob? and mabye have someone else put the car in reverse while its running then look for yourself...cuz mabye ur tryin to find out for urself if there working by putting it in reverse while its not running....
wow shitty warranty..i got 5 year or 150 000 kms on my car
Old Sep 17, 2007 | 09:06 PM
brianm01's Avatar
I've tried that with no results, i'm noy sure were the reverse sensor is located, i'm thinking maybe that it may be broken or a plug came loose, the only two sensor that i've found so far are on the bell housing and the plus were tight.
Old Sep 18, 2007 | 12:26 AM
WopOnTour's Avatar
The back up lamp switch on your tarnny is not on the "bell housing" it's lower near (just above) the LH axle/output shaft. It has 2 wires, pink and light green. If you find the switch you can do a bsic diagnostic. Unplug it and with the IGN SW in the RUN position, "jumper" across the 2 wires and the back up lamps should turn ON. If they DO the switch has issues, if they dont - you have other "circuit" issues.
In THAT event the next check is to confirm B+ on the pink wire with a test lamp and we can go from there...
WopOnTour
Old Sep 18, 2007 | 05:42 PM
Joel's Avatar
Mine did the same thing a few months after I got it. I took it to the dealer and they said that I had a bad ground...I never asked where. I know that's not too helpful, but maybe a start....
Old Sep 18, 2007 | 07:59 PM
brianm01's Avatar
I did what you said with the jumper and sure enuff the lights came on. it's a bad switch, i'll order one from new gm parts. thanks for your help WOT +1 for you.
Old Apr 12, 2008 | 05:03 PM
Video2402's Avatar
How do you check it?
chefhhr
Oct 26, 2015 10:36 PM
How to Guide
57
Oct 15, 2015 11:56 AM
royce777
Sep 28, 2015 07:11 AM
ashalle2
Sep 17, 2015 04:58 PM
TrevorB
Sep 14, 2015 03:59 PM
