Rough Idle..Ingalls to blame?
Old Nov 28, 2008 | 09:38 PM
06superchargedbalt's Avatar
Hey guys, got a quicke...My car I noticed today..and it's in pretty cold temps, that it has sort of a rattle at low RPM. It only does it at idle, and I have my ETD on a pretty tight setting. I don't know if it's that or it's simply that the car is warmed up enough to idle at around 850-900RPM? I don't know, I just noticed it..but maybe it's done it all along and I haven't noticed. Mods are in Sig.
Old Nov 28, 2008 | 09:40 PM
drop-n-destroy's Avatar
if its a rattle then most likely it is the TD. I have a motor mount and when the temp started to drop i noticed more vibs
Old Nov 28, 2008 | 09:42 PM
Yeah because it goes away with more RPM..I think it's the ETD the more I think about it.
Old Nov 28, 2008 | 09:47 PM
Im pretty sure it is that. usually rattles at 1000-1500 rpms. Maybe try loose it up a lil bit just for the winter. That way less rattles, and more TD life.
Old Nov 28, 2008 | 09:49 PM
Yeah true...Plus I'm getting new tires soon, so I won't need it so bad.
Old Nov 29, 2008 | 08:30 AM
Coblasts's Avatar
Check your pcm module is not causeing the rattle they are in the holder pretty loose and you might need to wedge something beside it to firm it up.
Old Nov 29, 2008 | 10:23 AM
Well, it's coming from the passenger side...so it's probably the ingalls.
Turbo Johnny
Feb 21, 2019 09:41 AM
Solaris99
28
Mar 15, 2017 01:22 PM
bigdeertz
Nov 17, 2016 09:41 AM
Oct 13, 2015 09:32 PM
Trav3480
Sep 28, 2015 02:46 PM
