rpm fluctuating/stalling ? 06 SS/SC
Old Feb 6, 2009 | 08:18 PM
motogp34's Avatar
Has anybody had any issues with the engine rpm fluctuating while the car is rolling while in neutral or with it in gear but you have the clutch engaged ?
When i came to a stop with it in neutral or clutch engaged the rpm fluctuate and sometimes the car stalls on me. It has done it from day one, but has become more frequent over time.
I have had it at the dealer 3 x, but no engine codes come up and have had the computer re flashed twice.
It only does while the car is rolling, not when i have come to a complete stop, and the car has to be in neutral for it to do it, not while the engine is under load.
Other then that the car runs great !
Old Feb 7, 2009 | 09:30 AM
Coblasts's Avatar
If the reflash didnt fix it(There is a tsb out on that which says to reprogram the pcm)
Then I would tend to think there is a sensor problem(wheel speed sensor)One of them maybe putting out irregular signals and confusing the pcm causing the irregular idle,
I know are cars hold the idle up until you come almost to a complete stop and then drops to idle rpm
so that would make me think that the wheel sensor might be buggered.
I would recommend that you tell the dealer to call someone in that specializes in trouble shooting these problem because you want it fixed once and for all.
another question ,does it do with the air con off,remember the air con is on if you have it in defrost and not if you have it on floor only.
Old Feb 7, 2009 | 11:49 AM
motogp34's Avatar
it doesn't matter,
i have brought it to 3 different shops, one told me it might be a bad computer and the other said it might be the mass air flow sensor...
the car is now past its warranty now
Old Feb 7, 2009 | 11:55 AM
sport08's Avatar
i think i read somewhere about someone having this problem and they cleaned there throttle body and it stopped having this problem ill c if i can find the thread
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/idle-problem-cure-finally-116051/ <<<read this see if its the same problem
Old Feb 7, 2009 | 12:31 PM
motogp34's Avatar
that is my exact problem, i`am going to give it a shot !
Thx
Old Feb 7, 2009 | 12:51 PM
sport08's Avatar
Thx
yeh i thought it sounded familiar hope it works for u
Old Feb 7, 2009 | 07:16 PM
motogp34's Avatar
just did it today, FIXED
Old May 6, 2009 | 11:18 PM
Kolt's Avatar
Mine is doing the same thing! Except it only does it while sitting still and the first time it did it all the info stuff reset itself. I was told to clean the throttle body and check for dirt( doing it in the morning) but what does that have to do with everything resetting? ECM prob maybe ya think?
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Trav3480
Sep 28, 2015 02:46 PM
Infamous SC/SS
Sep 4, 2015 05:33 PM
