RPM stays at 2500 rpm when in nuetral
Old Aug 4, 2011 | 09:54 PM
mandk1229's Avatar
So I need some help. I'm not sure why my car is doing it but sometimes it will all of a sudden rev all the way up to 2500 rpm when it's in nuetral. When I go into gear it will drop until I go overthat amount then will want to continue to stay about 2500 rpm. I took it to the dealership here in cali but they said they want to charge me for three hours of diagnostic charges due to me having modifications. They have previously made repairs on my car but for some reason won't touch it this time. Could this issue be a dirty air filter or maybe an electric problem? please help!!
Old Aug 4, 2011 | 10:06 PM
Coblasts's Avatar
Might be your evap purge stuck open allowing gas fumes to enter the throttle body.But generally you would have trouble starting it after filling the tank if it was.
Any other things that you have notice?
Is the gas pedal coming all the way up?
Might be a dirty throttle body as well!
Old Aug 4, 2011 | 10:13 PM
mandk1229's Avatar
crazy thing is, is that when that happens if I shut the car off it has problems restarting!! Seems like it started right after I was almost out of gas. Ever since then it will happen then work fine and all of a sudden start over revving. I had the throttle body and sensor replaced about 6 months ago due to it staying in rep mode.
Old Aug 4, 2011 | 10:16 PM
nhanson's Avatar
possible vac leak?
Old Aug 4, 2011 | 10:23 PM
mandk1229's Avatar
not that I can tell, if I had a vac leak I would suspect that it would stay like that. I can drive my car for a few days and the issue won't happen. I could take the throttle body apart and see if that's the issue and also clean the cai and see if that helps. I hate dealerships and I worked at a chevy dealer for 4 years selling.
Originally Posted by nhanson
possible vac leak?
Old Aug 4, 2011 | 11:03 PM
Coblasts's Avatar
Give the evap purge selinoid a bit of a rap to see if it unsticks it.
Its located on the right side of the rocker cover when looking at the motor.
It actually bracketed to the side of the engine.
Old Aug 5, 2011 | 06:45 AM
06SS ALL DAY's Avatar
it wants to race people from a dig...
Old Aug 5, 2011 | 06:51 AM
donald's Avatar
mine did that after i cleaned my throttle body and i just let it sit in the sun for a week and i guess it dryed the electronic part of the tb out but whatever you do if you clean it spray it on a rag first then wip it you might need a new throttle body though
Old Aug 5, 2011 | 06:57 AM
if he needed a new tb he would go into limp mode and throw a code for TPS sensor and such. ive been down that road already lol, not fun
Old Aug 5, 2011 | 07:27 AM
donald's Avatar
ya i guess thats what mine did
Old Aug 5, 2011 | 03:15 PM
mandk1229's Avatar
cleaned throttle body, seemed to hel;p for the most part. Didn't realize another issue that is ongoing and seems to me to be related. My coolant temp never goes over 105 degrees, when it over revs the coolant temp shows around 28 degrees which we all know isn't possible when i live in socal. Any suggestions? would the solenoid be the issue with this? And my car did go in limp mode 6 mos ago and the throttle body was replaced.
Old Aug 5, 2011 | 08:49 PM
mandk1229's Avatar
anyone???
Old Aug 5, 2011 | 11:20 PM
Do you have a catch can? If not u obviously know my next suggestion lol. Your coolant doesnt see normal operating temps? Wtf maybe the tstat is stuck open? How many miles are on the balt? Thats verrry odd. Ilthe lowest temp ive seen with lnf n lsjs with a stuck open tstat was like 160deg F. Never 128 lol
Old Aug 6, 2011 | 12:03 AM
08SSTCRD's Avatar
Sounds like you may have a faulty ECT (engine coolant temp) sensor. If it shows cold it will richen the fuel mixture and increase RPM to try and get the car to warm up. Check the ECT as well as the wiring for a problem.
Old Aug 6, 2011 | 01:36 PM
mandk1229's Avatar
that has to be it!! I was driving to play hockey last night and my coolant said it was -40!!!! With the coolant temp going under 60 is when my rpm goes up. I may have a electrical problem because I also got a stupid cel for a p2226 and a 90069 code. Cleared them and they haven't come back yet. Also my sunroof will work and then not work. Only thing electrical I have done is my hid's and that's it, and i didn't even hook up the halos. Should I force the dealer to look at it or is it something I can figure out?
Old Aug 6, 2011 | 07:58 PM
mandk1229's Avatar
Old Aug 7, 2011 | 03:16 PM
mandk1229's Avatar
ok so this was a really really really simple fix!!!!! I unhooked the coolant sensor and plugged it back in and fixed all my issues. Thanks for all of your help people! I can always count on my ss.net fam rather than the dealership
Old Aug 7, 2011 | 03:38 PM
paintballerr78's Avatar
ya the reason it was staying revved up so high is cause the car was basically staying in warm up mode since the coolant wasnt heating up it was staying there thinkin its super cold outside
Old Aug 7, 2011 | 08:58 PM
mandk1229's Avatar
it was crazy!! and not cool with cops thinkin i was trying to race lol
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
Tupp
Sep 30, 2015 08:18 PM
Trav3480
Sep 28, 2015 02:46 PM
jmelton327
Sep 26, 2015 10:04 PM
