RPM Up and Down on Rev
Old Oct 9, 2006 | 01:05 AM
SuperEco06's Avatar
Cool RPM Up and Down on Rev
Ok, I may be making a big deal over nothing, which i hope is the case.
When Im out of gear, e brake on in my 06 SS/SC, and I rev it to about 3500 rpm and let off the gas, the rpms drop to about 1200, rev back up to 1500 or so, and then back to the idle at 800. (note that when it goes up and down, my foot is not on or near the gas, engine does it on its own)
Any idea guys?
Old Oct 9, 2006 | 01:17 AM
SSweet06's Avatar
My car has done that since the day I bought it. Even after stage 4 and tune still does it. I'm thinking its a cobalt thing but if anyone has any info, I would like to know also.
Old Oct 9, 2006 | 02:28 AM
SuperEco06's Avatar
at first i thought it might be residual pressure in the manifold causing the comp to go cuckoo but im not too familiar with how EMS work so i may be wrong
Old Oct 9, 2006 | 03:24 AM
TexasTieaga's Avatar
When I start my 2.2 (warm or cold) my rpms drop to 600, rise to like 1500 then dip again and rise again and then settle at about 950 and slowly drop to 800... did that since the day I got it... didn't think it was hurting anything so I jus let it ride...
Old Oct 9, 2006 | 09:12 AM
rnjmur's Avatar
This is normal. My car's RPMs jump around a bit whenever I give it some gas then let off. I think at least all the SS/SC have this. It is not as bad as long as you have the latest ECU flash - that helped mine alot.
Old Oct 9, 2006 | 09:25 AM
bigd2114's Avatar
same issue hear not worried about it....although did notice some smoke one day thinking it was running to rich but w.e. just time for a smaller pulley then
Old Oct 9, 2006 | 10:57 AM
ItalianJoe1's Avatar
It is the car trying to burn all the fuel you dump into the motor when you rev it like that. It's for emissions, and its only possible because of the electronic throttle control. Normal operation, so don't bother with it. It is kinda funny though.
Old Oct 9, 2006 | 11:01 AM
HunterKiller89's Avatar
maybe to keep it from idling? keeping the RPMs from dropping too quickly whe in the lower ranges
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
Trav3480
Sep 28, 2015 02:46 PM
DocSvensk
Sep 27, 2015 02:24 PM
SStevie
Sep 21, 2015 11:37 AM
