SCANXL with GM Addons Diagnosing P0106
I have a MAP sensor problem with my GMS1 upgrade that just starting showing up after ~two years. I intermittently get P0106.
I got SCANXL with GM add-ons and I see the following:
GM.ENGINE.MAP_SENSOR_B fluctuates a lot (1-3V) during idle and GM.ENGINE.MAP_PERF_TEST2 fails on and off as well.
I cleaned the top sensor, replaced the sensor and I see the same issue.
I checked wiring and it seems OK.
I haven't tried replacing the bottom sensor as this seems to be related to the top sensor.
Not sure what the MAP PERF TEST2 means or what MAP_SENSOR_B related to (lower or upper MAP).
I think it probably is the lower MAP that has the problem. I will investigate tomorrow...
Any ideas?
Any ideas?
