Serious Problem Wiring & Fuses
Old May 17, 2008 | 03:34 PM
galeblanc's Avatar
Hi,
I was trying to wire up some LED's and ran into some problems. What I did was cut a 12V wire and split it to put my LED connection. Everything lit up and was fine until all of sudden it stopped working and didn't light up anymore. I ALSO CAN'T START MY CAR, I GET A "POWER STEERING" message of my display??
The wire I cut was on the passenger side, pink/white, and it came from the cigarette ligther area to the red compartment below the fuse box.
I'm assuming it is a fuse, but which one? Anyone have an idea?
Please help ....
Gabriel
Never mind, problem solved. It was fuse #25 in the passenger fuse box. TCM/ICM i think.
The LED interior lighting plans are cancelled.
Old May 17, 2008 | 03:35 PM
mkulrey13's Avatar
you need resisters....
Old May 17, 2008 | 04:25 PM
galeblanc's Avatar
I'm done playing with electronics. I hate it with a passion. I don't mind mechanical work but when it comes to electrical stuff, I really hate it. It's unpredictable.
That's why I'm a mechanical engineer and not electrical!
Old May 17, 2008 | 04:26 PM
OriGinaL Condo's Avatar
How about if someone does writeup on the proper way to install LEDs?
Old May 17, 2008 | 05:56 PM
galeblanc's Avatar
I'm sure that would help. I guess I just chose the wrong 12V wire and blew the fuse. That's why I'm giving up for the time being unless someone were to do a good how to and show exactly which wire would work. I can find several grounds, but I just don't know of a good 12V wire. For me, it was just a guessing game, trial and error.
Old May 17, 2008 | 06:42 PM
highrider43's Avatar
OK, for starters you cant just go around cutting and splicing just ANY wire you find with power and hooking stuff up to it.......your going to get yourself into a lot of trouble that way......The proper way to hook up any electrical device wheather it be lights or whatnot.....is to use a RELAY......Now i understand that a lot (well most to be honest) of people do not know how to wire a relay or are scared to do so.........Its actually quite simple and there are a lot of how-to's on the internet or this site to show you how to wire them up......When you use a relay you can use an ignition wire or a park light wire or what ever you want really to make the relay "come on".....This draws very little amperage from the circuit and generally does not cause problems......Or you can run a constant power from the battery and put a switch of some sort inline so you have full control of what ever it is you want to turn on.......I dont think i need to go into any more details but this is a good start for some people that are having trouble with wiring......12 volt wiring is the easiest wiring to do because you only have a power and a ground....so dont be scared to experiment and eventually you will be come a master.........Later
Old May 22, 2008 | 02:31 PM
JayB1127's Avatar
Im going to second this, Im having problems as well, only Im testing mine before I hook it into the car....
Jay B
Old May 22, 2008 | 09:26 PM
galeblanc's Avatar
I guess I'll look into getting a relay. I assume my fuse blew cause the LED's were pulling too much current. The other problem I have is that I never know which wire to split. I guess I'll ask my friend to pull me out some wires (He's a car alarm system installer). I'm sure he can help. He did that for my previous car and the LED's worked great.
I hate installing LED's with a passion.
Old May 22, 2008 | 09:35 PM
midniteracr06's Avatar
best 12V wire to use/find is the one going to your cigarette lighter. i cut and spliced that one to wire in fog lights. no problems with blowing fuses except when i plugged in an ac/dc converter to the cigarette adapter...then i blew a fuse because it drew way to much current. but for LED's..that power source should be more than sufficient.
Old May 22, 2008 | 09:36 PM
njg5gt's Avatar
i wrote this how-to for g5-club. you can pick out the essential information from there that should help out
http://www.g5club.net/forum/viewtopi...st=0&sk=t&sd=a
Old May 25, 2008 | 10:17 AM
galeblanc's Avatar
Thanks, that seems perfect. Next time I try to install them, I'll follow your instructions!!
Old Aug 11, 2008 | 08:57 PM
tony2toness/sc's Avatar
whats up guys hey i have a problem i lost one of the fuses that say 30 on it wich controls the car electronic causes i took it off and everything turn off but i lost that fuse so i took another fuse that said 30 on it and put it on the other port but what they control
Old Aug 11, 2008 | 10:29 PM
Coblasts's Avatar
Canada Heres your answer
Under the hood
BCM 3 Fuse
30A
Body Control Module (BCM)
CNSTR VENT Fuse
10A
Evaporative Emission (EVAP) Canister Vent Solenoid
COOL FAN1 Fuse
30A
COOL FAN2 Fuse
30A
CRNK Fuse
30A
CRNK Relay
29
PWR WNDW Fuse
30A
Driver Window Switch, Front Passenger Window Switch
In the bcm
Old Aug 16, 2008 | 10:10 PM
damn so im running on one fan how bad is that will my engine heat up badly or will it run ok with the other fan
you wouldnt happen to have a picture to see were they are position so i know wich one i disconnected im hoping its from the fan
Last edited by tony2toness/sc; Aug 16, 2008 at 10:10 PM. Reason: Automerged Doublepost
Old Aug 16, 2008 | 10:55 PM
07Maliboo's Avatar
if you guys need help with led's go ahead and pm me. I'm pretty good with lights. I've wired my whole car myself. (I got pics if you wanna check it out). a switched line is best and if anything seems to be wrong withyour lights then you can always turn it off which completely disconnects power to your lights.
Here's a helpful little link
Here's another to calculate the resistor you need to use.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
