Serious problems
Old Apr 17, 2013 | 10:47 PM
billyboy2287's Avatar
Serious problems
Car was good parked it for 3 days then needed to jump it. Jumped it an it went into reduced engine power. After 20 minutes it was fine. The next day had to jump it again this time had to leave a jump box on it to get it to where I had to go. The next day I could not even jump it. The battery has 2 volts. Here is the kicker. I disconected the battery and just hooked up the jump box and tried to jump it. It would of had enough power to sustain it for a little bit to run test. It will not even start it just clicks. Now there is a huge draw. You can just tell when you hook the box or cables from the spark. I do not have any after market acseroies either. Even when the jump box is fully charge it will drain it within 30 seconds. I did not hit anything or go anywhere wet or crazy. Like I said I parked it for 3 days and this is what happens. I am pretty good with cars worked at a shop for a good while. Have not had much time to get into it but I can just tell this is going to be a pain in the ass. Based off what is going on now its not the battery or the alt. Anyone help its a 2006 cobalt ls I believe it has the 2.2. Thanks guys .
Old Apr 17, 2013 | 10:52 PM
Xmetalhead2003X's Avatar
Sometimes a bad jump with these cars, or the power sterring module can cause the pcm or tcm to fry due to load, worst case scenario. Mine ate one a while back.
Old Apr 17, 2013 | 11:10 PM
JapEatr's Avatar
South Central *********
Dead battery /thread
Old Apr 17, 2013 | 11:19 PM
turbosmart4's Avatar
Bad alternator or battery
Old Apr 17, 2013 | 11:21 PM
JshLnsctt's Avatar
This.
Old Apr 17, 2013 | 11:28 PM
Dead batt ..I disconnected the bat and hooked up a jump box and I tried to jump it with a another car at the same time. It should have fired up
It should have started with the jump box even if it was bad..I have two jump boxes and they were fully charged and even jumping it should have fired it up
Originally Posted by JshLnsctt
This.
dont think sooooo
Either way I cant even start it to test the alt. It was workin to where I could jump start it or use my jump box now as soon as I hook up the jump box fully charged it drains them within 30 seconds. As soon as I hook up the POS you can see it arc its not normal.
Old Apr 17, 2013 | 11:32 PM
Buy a battery at walmart
Old Apr 17, 2013 | 11:33 PM
lwpmoon's Avatar
Bad Battery. Car batteries are lead acid batteries and they are quite picky... Here are some pros and cons!
Pros:
Cheap
Cons:
Heavy
Don't like to be overcharged
Don't like to be undercharged
Don't like to get too hot
Don't like to get too cold
Don't like to be completely discharged
Don't like to be charged too quickly
Don't like to be discharged too quickly
And it goes on and on...
Keep in mind that a 12V car battery is considered dead at 10V, so if you only saw 2V I guaranty that you need a new battery.
Now we need to think about what caused the drain before a new battery is installed.
Old Apr 17, 2013 | 11:42 PM
JshLnsctt's Avatar
How old is the battery?
Old Apr 18, 2013 | 10:33 PM
It's not the battery. The jump box is a battery ....Ok i will play it this way the battery is brand new .....So now what ? Alt is putting out 14 V
Old Apr 18, 2013 | 10:55 PM
Tomtwtwtw's Avatar
If your battery cells are beyond fubar'd, they may not even be able to pass a current, let alone generate one. Had the same situation as you on my woman's car years ago - couldn't even jump start it. Ended up being the battery.
Old Apr 18, 2013 | 11:32 PM
JshLnsctt's Avatar
A jumper box has a battery in it the same size as a motorcycle/ATV generally, I wouldn't rely on it to provide full power to the car in every situation. I would at minimum verify the age of your battery.
Old Apr 18, 2013 | 11:45 PM
Check the battery cables. Make sure they aren't corroded which would impede the current flow. You might be losing power to the starter.
Old Apr 20, 2013 | 01:57 AM
Finally was able to get the car running. While its running the voltage does not change in fact it slowly drops meaning its sucking power from the batt. Alt is bad infact I am 99 % sure thats where the draw is coming from since its bad somthing is screwed up inside. Expensive too 150 plus 50 dollar core charge I am getting a used one for now. Last question I did not check the output of the alternator directly I just checked the main power cables is there a regulator other than the alternator or is it only built on the alternator.
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
dennis69
Sep 28, 2015 02:16 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
