shaking of front end
Old Nov 3, 2010 | 12:12 PM
deereboy4320's Avatar
i was doing about 110 when i needed to slow down and when i started the front end started shaking. would this be considered "normal" or is there a problem?
Old Nov 3, 2010 | 12:14 PM
TommyP's Avatar
AWD > FWD
Warped rotors if you were braking when it happened.
Old Nov 3, 2010 | 12:15 PM
recklessactn's Avatar
car stock? lsj? milage? you probably need an alignment but for now take off your front wheels and then re torque them correctly back on. Had a similar problem at 65/70 bc tire shop didnt put them on correctly.
Originally Posted by TommypSS/TC
Warped rotors
this too^
Last edited by recklessactn; Nov 3, 2010 at 12:15 PM. Reason: Automerged Doublepost
Old Nov 3, 2010 | 12:22 PM
Nacademus's Avatar
this too^
Come on guise... there's no such thing as warped rotors
Old Nov 3, 2010 | 02:20 PM
[QUOTE=recklessactn;5346593]car stock? lsj? milage? you probably need an alignment but for now take off your front wheels and then re torque them correctly back on. Had a similar problem at 65/70 bc tire shop didnt put them on correctly.
yes the car is stock except for exhaust, has about 57,000 miles and i assume by lsj you youu mean model which it is a ls 2 door
Old Nov 3, 2010 | 02:29 PM
the_cobalt_kid's Avatar
LSJ is an engine code. if you have an 2DR LS you DO NOT have an LSJ.. LE5 i think is what you have... i think... not sure... someone will correct me if i'm wrong.
Old Nov 3, 2010 | 02:36 PM
TommyP's Avatar
AWD > FWD
if his car is an 05-08, his motor is the L61. If it's an 09-10, he has the LAP.
Old Nov 3, 2010 | 05:07 PM
its an 06
Old Nov 3, 2010 | 06:53 PM
well try what i said first if that doesnt work wheel alignment and going 110 in an ls is scary..... bc it takes a long time to get there lol
Old Nov 4, 2010 | 12:09 PM
ha ha actually quarter mile is 92
Solaris99
28
Mar 15, 2017 01:22 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
Bohb
Sep 27, 2015 09:11 PM
grampss
Sep 27, 2015 08:51 PM
