shift linkage won't work when very cold
2009 SS
Anyonelse have this problem? I have to let it warm up for 1/2 hour when it is below zero. Car is not garaged. The shiftlever won't move laterally it will move up and down until the cab warms up. It shifts perfect when warmed up inside cab or above 0 F outside.
Pretty normal when it's 0. The transmission fluid is probably as thick as molasses.
Might want to check that the two cables still have the seals at the end near the transmission and aren't getting water in them and freezing.
this is for replacing the pin that connects the shifter cables to the transmission. it has pictures that you need
https://www.cobaltss.net/forums/how-...ission-102830/
Turbo Johnny
Feb 21, 2019 09:41 AM
The Rookie24
Sep 20, 2015 04:33 PM
jcalvin1126
Sep 11, 2015 10:24 AM
