Smells like gas
Old Sep 14, 2008 | 11:34 PM
06blackbalt's Avatar
Smells like gas
I got a problem whenever I drive my car and then park it it smells like gas really bad only on the outside what do you guys think is wrong?
Old Sep 14, 2008 | 11:52 PM
Maven's Avatar
Mos likely cause is an animal ate through or road debris damaged a part of your EVAP system.
You need to find the source, fuel VAPOR is what ignities.............
Old Sep 15, 2008 | 12:07 AM
i got under the car to look and nothing was leaking but i could smell it
Last edited by 06blackbalt; Sep 15, 2008 at 12:07 AM. Reason: Automerged Doublepost
Old Sep 15, 2008 | 12:11 AM
outtamymind's Avatar
are you sure your not running rich or anything like that?
Old Sep 15, 2008 | 12:19 AM
yea im not running rich
Old Sep 15, 2008 | 10:21 AM
Maven's Avatar
If you can smell it theres a leak, not necessarily a liquid leak, like I said most likely cause is a damaged vapor line.
Old Sep 18, 2008 | 10:04 PM
i found the problem there is a crack on the top of the fuel pump housing i had to drop the tank
Old Sep 18, 2008 | 10:05 PM
Super_SS's Avatar
yea my **** runs smells like gas also, but i have straight pipes
Old Sep 19, 2008 | 10:58 AM
SCcobaltSS's Avatar
I have noticed mine has just started smelling like gas lately. You found a crack at the top of your fuel pump housing? Did you fix it? Did it work?
Old Sep 19, 2008 | 11:05 AM
Maven's Avatar
If youre car has california emissions, the cracked pump may be covered for 150,000 miles.
Old Sep 19, 2008 | 01:20 PM
SCcobaltSS's Avatar
Do you think this would be covered under my powertrain 60,000, I have an extended but would rather not pay the deductible. Sorry if I jacked this thread, similar problem want to try to get resolved.
Old Sep 19, 2008 | 03:07 PM
Maven's Avatar
No, the fuel pump is not covered under the powertrain warranty.
Old Sep 19, 2008 | 03:16 PM
Tomtwtwtw's Avatar
Yes it is.
http://www.chevrolet.com/warranty/terms/#terms
Old Sep 19, 2008 | 06:45 PM
Maven's Avatar
Originally Posted by Tomtwtwtw
2006's dont have the 5/100 warranty, they have the 5/60 which is a completely different policy, and to my knowledge and in the quick searches I did, Ive found no mention of the fuel pump being covered under the Cobalt 5/60 Powertrain. It would be great for these guys if it is though, but I dont wanna give out false hope.
Old Sep 19, 2008 | 09:21 PM
i have 98,xxx miles, i had to get a whole new pump
Old Sep 19, 2008 | 09:50 PM
SCcobaltSS's Avatar
well i have the extended.... i guess if i go to the selling dealer they will waive the 100 dollar deductible.... So mine will be free.. But thanks for the info guys
Old Sep 24, 2008 | 05:08 PM
SCcobaltSS's Avatar
It was the throttle body housing, the dealer is fixing it and should be good as new.. Funny thing is I have 36000 miles... Quick to go!
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
