So it rains and something goes wrong.
Old Oct 22, 2009 | 01:19 AM
AcAnderson's Avatar
Exclamation So it rains and something goes wrong.
When it rains for about a full day, and I drive my 06 2.0 SC, the day after and sometimes later in the day of, my car will seem to hit its rev limiter or jerk very hard approaching 3 rpm or 5 rpm (depending on how much it rained). What the hell is wrong? Put some codes and all it said was clean your injectors and maybe an O2 sensor.
-Adam
Old Oct 22, 2009 | 01:22 AM
steven2008ss's Avatar
Clean your MAF Sensor, it could be dirty, same happened to me, if you have a CAI, check it out.
Old Oct 22, 2009 | 01:23 AM
DecoyGSX's Avatar
Get code numbers, I've never heard of a code saying to clean injectors (learn/rich?) and a 'maybe '02 failure is a pretty big hit to engine performance. These codes set when conditions are met, and some are pretty crazy, so...
Old Oct 22, 2009 | 01:25 AM
AcAnderson's Avatar
Sorry, I'm not to auto-inclined. CAI? Otherwise I know what your talking about.
Thanks
-Adam
And if you can easily tell me/show me, where is the MAF sensor located?
-Adam
Last edited by AcAnderson; Oct 22, 2009 at 01:25 AM. Reason: Automerged Doublepost
Old Oct 22, 2009 | 01:28 AM
skatin_boarding's Avatar
-Adam
Mine did the same thing this summer after i would wash my car. My theory was just a little water would seek through the intake and do something but it would run fine after a little while. Then my buddy told me no that probably wouldnt cause that so I really dont know. I would like to know why as well.
DecoyGSX's Avatar
Do you have your warranty?
If you need those codes pulled again go to an Autozone and ask them to print out a slip on each one to take home, once they run the codes. It has the numbers, and definitions of the code on the slip.
CAI = Cold Air Intake, and if your not familiar with this, I'd leave the MAF alone... Too easy to mishandle or spray the wrong stuff on.
Old Oct 22, 2009 | 01:32 AM
AcAnderson's Avatar
I dont have a warranty. Im familiar with cold air intakes i just didnt know the acronym. But yeah Ill check it out.
TY
-Adam
Old Oct 22, 2009 | 01:36 AM
SSReepur's Avatar
Mine does it but i think its because water gets in my intake, i kno its not good but i dnt drive it wen it rains that much...
Old Oct 22, 2009 | 01:58 AM
Tomtwtwtw's Avatar
This also happened to me once on my ss/sc after heavy rain. On 1/4 throttle or so I could rev it fully, but if I gave it any serious gas, it would bounce off 4k like that was the rev limiter. Went away the next day. Never got a CEL or anything. I just assumed the MAF got a little damp and the car wasn't reading airflow correctly - hence the low rev-limiter under throttle to protect the engine.
Old Oct 24, 2009 | 01:30 AM
bingo exactly the same thing
Old Oct 24, 2009 | 11:08 AM
Ramphex's Avatar
It's the MAF getting wet, I have a cold air intake as well and that **** always happens... sucks but something got to deal with
hacadacalopolis
Oct 28, 2015 06:09 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
vjoel2011
Oct 2, 2015 12:11 PM
jmelton327
Sep 26, 2015 10:04 PM
