Spec 2+ clutch problem
Old Aug 24, 2006 | 01:50 AM
Shortbus's Avatar
My clutch has no play to it, gets stuck to the floor, it is leaking fluid, and will not go into gear, any ideas guys.
Old Aug 24, 2006 | 01:54 AM
SSinPhilly's Avatar
your problem is whoever installed it. I have had no problems yet.
Old Aug 24, 2006 | 02:08 AM
victory_red_SS's Avatar
LSX RWD S/C conversion
A mechanic friend says bleeding the newer Chevy's clutch is a real pain, worse than the install itself. The installer likely just didn't get this one right. Good luck.
Old Aug 24, 2006 | 08:17 AM
Shortbus's Avatar
So looks like i will have to bleed it again, i wonder where it could be leaking from though.
Old Aug 24, 2006 | 08:26 AM
CobaltBurst's Avatar
this is making me not want to change my clutch
Old Aug 24, 2006 | 08:39 AM
djt81185's Avatar
bleeder valve not shut?
the c clip not installed on bleeder block
not tighten slave cyl fittings
Old Aug 24, 2006 | 08:41 AM
distillion's Avatar
my thoughts exactly...
Old Aug 24, 2006 | 08:43 AM
StinkBOMB's Avatar
Yeah, except for that clutch slip on the 1,2 shift I wouldn't even consider it. I still don't know if it's the clutch or if it's something else, throw out bearing or slave cylinder maybe.
Old Aug 25, 2006 | 07:04 PM
yea thats all that is slipping on mine... the 1-2 shift, i can live with it until these things get worked out... GL shortbus
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
