Speedometer only going to 20 mph on f23 swapped LSJ
Old Apr 10, 2018 | 05:19 PM
Chanyeezy's Avatar
So I finished my f23 transmission swap from an f35 on my lsj, speedometer only going to 20 mph at max and low speeds doesn't really do much.. So it's wanting to do something but its not working right. Anyone had similar issues on these vehicles at all? Is there an input speed sensor on the manuals?
Old Apr 11, 2018 | 12:35 AM
Sharkey's Avatar
just a quick look at a couple tunes shows the reluctor wheels in the transmissions have different tooth counts. the f35 has 85 teeth and the f23 has 29 teeth. this can be changed using hp tuners under the speedometer settings.
Old Apr 11, 2018 | 11:05 AM
I did an f23 swap on an lsj (04 ion redline) and the speed sensor settings did not need to be changed. I compared the speedo with GPS after the swap and everything was right. I would check your sensor resistance and wiring job.
Old Apr 11, 2018 | 12:57 PM
Sharkey's Avatar
doesnt the 04 ion use the speed sensor on the intermediate shaft? i seem to remember that was a different tooth count than all other f35s
Old Apr 11, 2018 | 02:49 PM
Thats why I included the year. Im not sure that makes a difference.
Old Apr 11, 2018 | 03:53 PM
Chanyeezy's Avatar
I will double check the wiring tonight and if all is well I will see about possibly switching the speed sensors. Only person with hptuners near me is about 4 or 5 hours away
Old Apr 11, 2018 | 05:05 PM
For the time being if you need to drive the car, you can get a free GPS speedo app on your smartphone.
Old Apr 11, 2018 | 05:13 PM
Chanyeezy's Avatar
Will do man I appreciate it
Old Apr 15, 2018 | 01:17 AM
Bass_Waves's Avatar
If your near New Jersey. I can help you out. I just did an lnf and had to calibrate everything to a Cobalt. Took me a while but I got it down to the T. Using math!
I don’t trust gps to be exact like the car. It’s stupid close but not good enough for me to rely on it.
Old Mar 10, 2021 | 04:28 PM
Byrd's Avatar
Bump from the grave
I have an LNF F35 and swapped to an HHR F23. I have the same problem with the speedometer being off. In HPTuners I'm using 4.17 FD and 72,616.13 vss pulses per mile. I have also tried the F35 speed sensor in place of the F23 one and that didn't make a difference. Any halp?
https://www.cobaltss.net/forums/driv...4/#post7742908
Old Mar 15, 2021 | 01:45 AM
Sharkey's Avatar
when you changed the tune, did the gear ratio box have 3.84 in it, or was it set at 1.00?
in a fwd the final drive ratio doesnt factor into the vehicle speed calculations due to the location speed sensor. in a rwd with the speed sensor on the transmission, the rear end ratio plays into the calculation.
if you look at my above post, the f35 has 85 teeth, the f23 has 29 teeth. either try putting 2.93 in the final drive ratio box, or put that at 1.00 and multiply your pulse per mile box by 2.93
Old Jan 4, 2024 | 04:34 AM
Kamerica's Avatar
Did you ever get this issue resolved? I am having the same issue. Tried several settings in HP Tuners, wheels diameter, PSS setttings, final gear ratio, but the results are the same. Speedometer never goes over 20 mph. Any help would be appreciated.
coolbalt1
Oct 4, 2019 08:48 AM
06scbaltss
Jan 20, 2018 04:23 AM
Jamie1234567
Aug 23, 2016 07:23 PM
BoostedLemonPie
12
Jan 11, 2015 11:27 PM
Mr. Volvo
Jun 17, 2009 09:28 PM
