SPS info
I was gonna print off all the pages of updates for each section and take it into my dealer and see if they could do it
It is totally up to you to decide what you want to do. Print the info out, go talk to your dealer or who ever. If the dealer wont do it then find someone who will.
I just came from the dealership with a printout and they said that they usually don't do anything unless something is wrong or a customer complains about a possible issue, then they will check and see if any updates deal with that particular issue.
Well. I would find a private mechanic who is certified an ask them to do it.
The last time i used the tis2web service was to make sure my car got the right calibration when i got stage 2 . I really don't think it shows anything about new updates . When you see a NEW calibration on your Cal history , it's telling you that it has been flashed to a new calibration already.
When i checked mine yesterday , it hasn't changed at all from the print out i did last fall after i got the stage updates .
if you want to know how much your speedo will be thrown off go to
http://www.miata.net/garage/tirecalcold.html, also if you need any information about your VIN or VIN RPO's email me @ calculating_infinity_@hotmail.com, i work for a chev dealer and can get information off your vin for you
Basically it shows what SHOULD be in your car for a calibration, (including a Stage cal if purchased and installed correctly from dealer) NOT neccessarily what's actually IN your car.
You WILL loose any custom tuning if you get an update at the dealer, but anyone that knows how to use HPT will be able to reapply their various aspects of their tune to the newer calibration
WopOnTour
PS> This IS a repost from a couple years back, but NO IDEA where it is...
WopOnTour
WopOnTour
WopOnTour
can i assume these updates wont change the GM stage 2 settings? im thinking they shouldnt since the stage 2 code is listed under the VIN...
but i am goin in wednesday to get the updates. hope this does some good...
good luck
is there one big list i can just print... or do i have to do each and every one..
What it you click "Complete History" Does that mean it was done to my car already?
and printing out the calibration numbers really isnt neccessary and just a waste of your time.
The dealer techs cannot pick and choose the calibrations they install or anything like that. In general all they can do is flash your with the most up-to-date available calibration and that is all. So they cant technically even give you the "wrong" calibration or anything. (as long as they use the correct VIN for your car that is)
Plus, once they reflash it they cant even go back to the old calibration (without contacting GM Techline, and there must be adequate justification)
Besides unless you have access to a TECH2 or some other programming tool you couldnt even confirm the correct file numbers were present aterwards anyways...
Wop
No, the complete history just shows the revisions that have occured since SOP (Start Of Production) Your existing calibration would likely be somewhere in that list.
Wop
Wop
again thanks for chiming in. +rep
well mine was reflashed today,random cylinder misfire is now gone,woot1 best the car has run since i bought it.I made two threads today,one thanking Kasioboy and another about this thread and randomcylinder misfire.
the mother f'ing service manager wouldnt do mine. said that he wont do any update unless the car is running poorly or there is a CEL
thats such BS.
even after i gave him the print outs from the site he gave me some line about how the car might not need the updates and wouldnt run right
What a ******* idiot.
thats such BS.
remeber when you go there complain about a bad idle or something,this way they can.t charge you for it.
The link won't work for me. I receive this error:
E4214: WARNING: You have received this message for one of the following reasons:
1. Session has timed out.
2. Another user is using the same user id/password and has terminated your session.
3. Security violation - user does not have access to this application.
Hey guys. Can you please clarify something for me? If this website shows the complete history and you have to enter your VIN to obtain that information, you would think that it would be the complete history of what's been done to your car right?
