sputtering at a standstill?????
Old Feb 14, 2007 | 06:35 PM
g5mike's Avatar
My car has a barely noticable sputter when I.m sitting at a standstill,it goes away when I start moving,could it be plugs,injenfilter maybe the CA cat???
Old Feb 14, 2007 | 06:43 PM
stotte20's Avatar
i would check your plugs first. also it is cold out and that might play a role in what is going on
Old Feb 14, 2007 | 07:04 PM
montecarloman's Avatar
no CEL ?
Old Feb 15, 2007 | 12:50 AM
Matty's Avatar
I would guess plugs.
Old Feb 15, 2007 | 08:50 AM
g5mike's Avatar
hey Matty I was thinking about replacing the plugs tomorro anyways,any suggestions
Old Feb 15, 2007 | 12:53 PM
Matty's Avatar
Yah...don't **** it up.
I haven't been following what the best plugs for you guys are. As long as it is in the proper heat range you will be ok. NGK is one of the top quality plugs and call your dealer and ask them for the proper gap for your application (mods).
Old Feb 15, 2007 | 09:22 PM
g5mike's Avatar
had the code read and I clogged the ca dp already,this causing backpressure and random misfire,so can I gut the cat??? or should I put my stock one back on??????
Old Feb 15, 2007 | 09:39 PM
Matty's Avatar
Stick the stock one back on or suck it up and spend more dough on a catless one.
Old Feb 15, 2007 | 09:49 PM
g5mike's Avatar
The stock one was causing too much backpressure due to the cams,when I put this dp on it helped until I clogged it,I would prefer to gut it instead of buying onother dp
Adiaz1ss
Sep 26, 2015 11:51 PM
jcarroll53
Sep 24, 2015 07:43 PM
OrangeK
Sep 20, 2015 03:02 AM
SS/SC05/19/05
Apr 26, 2008 05:20 PM
RedfoxTwenty
Aug 15, 2007 01:03 AM
