stage 2 help!!!
Old May 9, 2008 | 05:24 PM
Cyclone's Avatar
stage 2 help!!!
Ok so i just got my car back from the dealer just got my stage to done! Everything is good the car pull's alot better and harder,but before i went and got it done i was only boosting 10psi @6400 rpm thought it could be do to where i live less air,But now that i got the stage2 done im only boosting 13psi@7000 rpm. I think it is my stock gauge is there anything i can do to check it out my self other then check for leaks and stuff cause i already have???
Old May 9, 2008 | 05:25 PM
D4u2s0t's Avatar
it's probably your altitude depending on where you are in colorado. the higher up you are, the less it will be.
Old May 9, 2008 | 05:31 PM
Bika's Avatar
Fail Less.
nope. its fine. stage 2 is about a 3 psi increase. and at your altitude, you will be boosting less than most of us.
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
