Stage 4 went to shit today....
Well last night at the track everything went great until i screwed up the clutch a bit on my second run. So it slipped all night. So my first run was the only one where the clutch was hitting and i hit a 14.087 with a 2.211 60' but it was better than any srt-4 i saw.
Anyways, last night i would here a slight, knock/tick when at redline, didnt think too much about it, i then filled up at a BP and it got a little worse. Then i get in the car today and its Ticking/Pinging like CRAZY when under high boost. I also got these to Codes PO172 &PO507, any help with these would be great. Then i was at a light b/c i was helping someone move and i go to accelerate and the car just bogs, i keep trying to go but it just bogs, not getting any KR or CEL. so i let it idle for a couple sec then try again... again bog... so i shut it off for 5 seconds started it back up and everything worked fine.... i think people are having this same problem.. even stock... all help is appreciated. What would lead to no knock to a shitload? bad gas? Plugs? |
gas could knock plugs could knock engine internals could be a number of things but i doubt its the gas did you upgrade to colder plugs with the stage 4?
yes it came with the colder plugs....
clogged cat?
dunno any idea where i can look up these engine codes?
i will look up the engine codes for you give m about an hour but if you installe dthe colder plugs and all vacumm hoses etc is hooked up then give me about hour max to see what i can come up with
yea here are your codes...
P0172----Fuel Trim System Rich P0507----Idle Speed High so your car is runing rich for some odd reason...the intence PCM tune has some awesome AF control so I dont think its that and the idle is of for an unknown reason to me... good luck hopw that helps. |
po172 is fuel to rich code so that could be fuel filter fuel pump o2 sensor somehting along that line im checking other code now
po172 is fuel too rich code so that could be fuel filter fuel pump o2 sensor somehting along that line im checking other code now
yea 06 got it srry i didint relize but yea thats the codes
ok great, thanks guys i just called the dealership and they were supposed to get back to me... hmmmm im stumped here.... ill check the plugs, and i have some octane booster ill through that in the tank and see what happens... any other suggestions? sounds like i need to get HP tuners.... is there a big difference betwee the standard and the pro?
could the exhaust cause any of this? b/c that is my only mod on top of the stage 4 kit...
if your gonna spend the money get the proversion due to its soon to be released data loging abilitys
it'll help you out alot as you continue to mod. |
make sure your o2 senors are working properly and secured in place and hooked up proper it could be causing it
now that you mentioned it when backing out of a driveway i hit my exhast on the gutter b/c it was such a big drop off, but after that it didnt want to idle. But this was after the engine codes had come and i cleared them...
have you pulled your plugs yet? That would be the first thing I would do.
Idle to high and rich codes leads me to believe you have an air leak somewhere, or your maff sensor has become contaminated. Also, gap your plugs to .032-.034 and try it again. I also recommend ZEX 8003 plugs.;)
Rob |
ok they are gapped at .035 right now, ill down them a bit, think that will help with the knock? also its stock intake, how would i know if the maf is contanimated? thanks Fast06 i was hoping youd chime in :D Do you think i should thrown in this octane booster??? And i was getting the codes before and the pinging before the exhaust thing...
If you hit the exhaust you may have cracked it or broke the seal which cause it to suck air in around the 02 sensr skewing the readings. Add some torco and see if the KR goes away. Let me know. |
whats torco? octane booster? b/c i have some that i bought just incase it knocked... i just pulled the first plug, the metal ring is fine, everything looks good on it. Im waiting on my buddy to get here with a small gapper so i can gap it lower.
Any ideas on how it changed from not knocking to knocking? and im going to check the torque on the SC bolts to make sure its still torqued correctly. Intake seems to be fine... ill retighten though... Thanks again for your help... but even though it said it was idleing high from the code.... i didnt notice it... |
i thinki know where the leak is coming from, i regapped my plugs, and started it up and you can here a whistle at idle coming from the supercharger... i checked all of the tubes they are fine, i have a feeling it is the gasket... it must have not held up from the re-install but it didnt sound like this before.... could this be it Fast 06?
usally a rul of thumb is to always replace your gasket after you atke it off you could use your hand and feel around if possible and see if you could feel some air comming out
You can also spray carb cleaner around the base of the supercharger to see if you have any leaks, it will idle up if you do
