starting problems
starting problems
okay guyus so lately my car hasn't been starting. Every time it takes about 7 to 10 cranks before it starts. sometimes it'll start for like half a second and then it'll die again kinda like it does whenever you don't do the safety feature or whatever where you have to unlock the car twice before starting but dies a lot quicker. I thought it was because of the cold weather but then it got hotter again and still doing that. If someone could please help me out I wouold be very much appreciated...
thannks----ashley
thannks----ashley
yes it's still under warranty and we really don't want to take the subs out because it took us an hour almost to try and fit the **** in there because the trunk is so freakin small..
no they won't blame it on that...your subs have nothing to do with anything but your recharging system in your car, I'm under the impression that they are powered off the battery or at least the amp is......and if they're powered by the stereo...you would blow that fuse before it ever damaged anything..... remember they have to provide you in writing the how your modification caused the failure of the part. If they don't in the end the dealership will pay your legal fees and still fix the car under warranty.
and yes it does sound like fuel pressure problem.....fuel pump or pressure regulator issue.........
roth
Sep 26, 2015 12:16 PM
