steering
Old Mar 17, 2008 | 10:37 AM
zzzzzzzz's Avatar
steering
has chevy come out with a fixfor our steering shaft yet
Old Mar 17, 2008 | 10:44 AM
alleycat58's Avatar
Uh. That came out a LONG time ago. I had mine fixed in 05 and have never had a problem since....
Old Mar 17, 2008 | 10:55 AM
zzzzzzzz's Avatar
well ive had 3 of those sukers put in, and 3 of those steering colums put in, and the rattle is back
Old Mar 17, 2008 | 10:56 AM
fiftyandsoco's Avatar
hm. wish i knew about this, so i could help.
Old Mar 17, 2008 | 11:02 AM
alleycat58's Avatar
OK what rattle? I've NEVER had a steering rattle. If you've got something rattling, it's not your steering column.
Old Mar 17, 2008 | 11:15 AM
zzzzzzzz's Avatar
its a hollow rattle sound coming from the front drivers side when i go slow over bumbs
they put in the most updated shaft and colum and they said that in time it will comm back.
Old Mar 17, 2008 | 11:16 AM
alleycat58's Avatar
That's bullshit, the problem in that case is not the shaft, it's a problem with the front sway bar end links.
Old Mar 17, 2008 | 11:22 AM
zzzzzzzz's Avatar
well the sound is like its coming from behind the dash
wouls bad end links make the front feel like the tires are loose
Old Mar 17, 2008 | 11:37 AM
alleycat58's Avatar
The steering shaft does not make a rattle.
No, the end links would NOT make the front feel like the tires are loose.
Old Mar 17, 2008 | 11:57 AM
zzzzzzzz's Avatar
when i turn the steering wheel back and fourth i can hear the rattle
Old Mar 17, 2008 | 01:36 PM
alleycat58's Avatar
Then that's a separate issue. The intermediate shaft problem that there is a TSB for is FIXED by replacing the intermediate shaft. The rattle from the suspension when turning or going over bumps is from the sway bar end links.
Old Mar 17, 2008 | 07:36 PM
montecarloman's Avatar
Oh yes it can. I have heard many, many I shafts rattle away when they get bad enough
#04-03-08-006B: Steering and Front Suspension Noise Concerns - Clunk, Rattle, Knocking, Pop, Shudder, Vibration (Diagnosis and Perform Necessary Repair) - (Aug 27, 2007)
Subject: Steering and Front Suspension Noise Concerns -- Clunk, Rattle, Knocking, Pop, Shudder, Vibration (Diagnosis and Perform Necessary Repair)
Models: 2005-2008 Chevrolet Cobalt
2006-2008 Chevrolet HHR
2005-2006 Pontiac Pursuit (Canada Only)
2007-2008 Pontiac G5
2003-2007 Saturn ION
This bulletin is being updated to add models, model years and additional conditions. Please discard Corporate Bulletin Number 04-03-08-006A (Section 03 - Suspension).
This bulletin provides information on six different steering/front suspension noise conditions.
Condition #1
Some customers may comment on a rattle or knocking noise that is heard in the front of the vehicle while driving at low speeds (5-15 mph [8-24 km/h]). This condition may be more noticeable while making a slow turn or on a loose/rough surface.
This condition can be duplicated by the technician using the following procedure:
1. On a rough or loose surface (i.e., gravel parking lot), make a sweeping turn (either direction) at 5-15 mph (8-24 km/h) to load the steering column, I-shaft and steering rack/gear mechanisms. (The testing on a rough or loose surface will allow the wheels to oscillate slightly and will make the rattle/knocking noise more evident and repeatable.)
2. Release the steering wheel while making the turn to take load off of steering components. This should initiate the rattle/shudder noise which is generated by backlash in the steering assembly as it is in a no-load float condition.
3. Remove the 60 amp EPS fuse (1) in the underhood fuse block.
4. Test the vehicle as in Step 1. Since the EPS motor is no longer powered, only the I-shaft and steering gear/rack will be loaded as you make the turn. If you hear the rattle/knocking noise during the turn, then the noise is being generated by the backlash within the steering column (assist motor gear mechanism).
5. Replace the 60 amp EPS fuse and repeat Steps 1 and 2 to verify that the rattle/knocking noise disappears when turning (loading steering mechanism) and can only be heard when releasing the steering wheel.
Correction #1
If the steering column is identified as the source of the rattle/knocking noise in the above test, replace the steering column.
Important: The noise in the steering column is generated from the metal to plastic gear backlash of the assist motor mechanism and will have a different sound than that from the steering gear. If the customer comments that they still hear a noise, it may be a different sound from either the I-shaft or the steering rack.
If the steering column is not identified as the source of the rattle/knocking in the above test, continue to diagnose the vehicle according to the diagnostics in SI.
Condition #2
Some customers may comment on a whine/hum noise from the steering column while making right hand turns at 5-15 mph (8-24 km/h). A slight whine/hum noise is considered to be normal for EPS so it will be helpful to compare to another like vehicle. If the vehicle exhibits excessive feedback/noise when compared to another vehicle, follow the correction procedure below.
Correction #2
Important: DO NOT replace the steering column.
Pull the 60 amp steering fuse (1) in the underhood fuse block. If this eliminates the whine/hum concern, contact the Technical Assistance Center for further information in order to repair the vehicle. If this does not eliminate the noise, continue to diagnose the vehicle according to the diagnostics in SI.
Condition #3
Some customers may comment on a clunk type noise coming from the front of the vehicle during a turning maneuver. This condition can also be felt through the steering wheel when the vehicle is stationary and the wheel is rotated from steering stop to steering stop. Typically, the clunk noise will be heard once for every 90° of steering wheel rotation in either direction. This clunk noise may also be noticed during low speed acceleration or deceleration, typically in light turns of the steering wheel.
The following are characteristics of this noise:
• This noise is very random.
• This noise is independent of the steering wheel angle and independent of the bumpiness of the road.
• This noise is a low frequency dull one and can be felt in your feet.
• This noise can normally be heard from the driver seat.
• This noise can be felt upon touching the steering gear from outside of the vehicle.
Note that you might also notice a slight scrub-type noise when turning the wheel back and forth. This type of noise is considered normal and repairs will not eliminate it.
Cause #3
This condition may be caused by inadequate lubrication of the steering intermediate shaft.
Correction #3
Important: DO NOT replace the steering gear or steering column assembly.
Replace the intermediate shaft.
Important: If the vehicle has already had a steering intermediate shaft replaced for a similar noise concern that the dealer duplicated, determine from the customer if the noise went away for a period of time and came back, or if the service shaft made no change. If the noise was gone for a period of time and came back, have the dealer replace the shaft again to verify we do not have a defective service shaft.
Condition #4
Some customers may comment on a rattle/clunk type noise coming from the steering column when driving over bumps.
Correction #4
The following steps have been found to be very effective in removing this condition.
1. Check for the possibility of the PCM and the TCM rattling/clunking together. If there is contact between these two modules, insulate the modules from each other using a small piece of foam.
2. Check that the retaining clip on the engine coolant surge tank is fully seated. If not, push down to seat.
Rattles/clunks in this area of the engine compartment may be heard as coming from the steering column while driving.
Condition #5 (FE1 Suspension Only)
Some customers may comment on a clunk, thump or rattle noise coming from the front suspension while driving over rough road conditions or when braking.
Cause #5
This condition may be caused by the lower control arm rubber bushing (rear) coming out of its steel sleeve (1). This will cause the lower control arm to make hard contact (2) with the body structure. This condition may be more prevalent in regions that use road salt during the winter months.
Correction #5
If the rubber bushing has moved out of the steel sleeve, replace the lower control arm bushing. Do not replace the bushing if it is still centered in the steel sleeve.
If this does not eliminate the noise, continue to diagnose using chassis ears to identify the source of the noise.
Condition #6 (Saturn ION Only)
Some customers may comment on a squeak, rattle, pop, or clunk noise coming from the front of the vehicle during suspension movement.
Cause #6
This condition may be caused by the interface between the front stabilizer shaft, the front stabilizer shaft insulators (bushings) and the front stabilizer shaft mounting clamp.
Correction #6
Replace the front stabilizer shaft insulators (bushings), if necessary, using the following procedure.
1. Verify the customer comment. Use Chassis Ear (SA9217NE or J39570) or a similar tool to determine the source of the noise. Refer to Noise Diagnosis - Front Suspension in SI.
2. If the noise is coming from either the front stabilizer shaft insulators (bushings) or the clamps:
Important: Check the Service Parts Identification label in the rear compartment (trunk) to determine the vehicle's suspension system type, then obtain the correct insulators (bushings) corresponding to that suspension system type.
• On vehicles built after VIN breakpoint 4Z125195, replace both front stabilizer shaft insulators (bushings). Refer to the Stabilizer Shaft Insulator Replacement procedure in SI.
• On vehicles built up to and including VIN 4Z125195, replace the front stabilizer shaft insulators (bushings) and clamps. Refer to the Stabilizer Shaft Insulator Replacement procedure in SI.
3. Verify the repair by repeating Step 1.
Old Mar 17, 2008 | 08:56 PM
alleycat58's Avatar
Interesting. I thought it was mine for a while, then I removed my end links and the problem went away. Gone over a year and never another peep out of them.
Old Mar 17, 2008 | 08:59 PM
WalkerSS's Avatar
I had my intermediate shaft replaced a year ago. The noise came back so they changed by steering column. No noise yet.
Solaris99
28
Mar 15, 2017 01:22 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
TedSS
26
Oct 10, 2015 04:30 PM
importkiller
Sep 30, 2015 07:18 PM
