striped the threads going into the coolant line
Old Jun 17, 2010 | 11:34 AM
scotch89's Avatar
so i'm not sure what this pieace is called. so its on the head, its right next to the coolant sensor, it has holes in the bolt. i think its called the steam line? i think it goes to the resiovr. but when i was installing my stage 2 i ended up stripping the female threads anyone now a way to fix it with out buying a head?
Old Jun 17, 2010 | 11:39 AM
Jbowman62's Avatar
thread chaser
importkiller's Avatar
maybe you can use
http://www.amazon.com/Permatex-81668.../dp/B000AL4WAS
Old Jun 17, 2010 | 11:52 AM
scotch89's Avatar
i was thinking about using something like that^^^^ but since coolant will be hitting it, it might fade away. it's not leaking now, but im going to install a new fuel rail, and i wanted to fix it before i put it back in. makes me wonder if they make another size bigger bolt to go there so you can tap it that size.
Old Jun 17, 2010 | 02:13 PM
DaBuzzard's Avatar
Your best bet would be a helicoil thread repair kit.
Not really cheap and a bit of work to install but way cheaper than a head and will last forever if done right
06MetallicBalt
Jul 20, 2025 08:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
riceburner
Sep 26, 2015 12:57 AM
