Sunroof Problem
Old Feb 28, 2007 | 10:09 PM
fastss25's Avatar
Sunroof Problem
Does anyone else's sunroof kinda look popped up a little bit in the back, like if you laid ur hand half on the sunroof and half on the roof it wouldn't be flat. I thought mine was cracked up a little bit and I went and opened and closed it and it still looks that way.
Old Mar 1, 2007 | 07:00 AM
Fade.To.Black's Avatar
yea mine is the exact same way.. and if you close the sunroof, and then open and shut one of the doors.. the sunroof will pop a little bit.. check it out :P
Old Mar 1, 2007 | 07:36 AM
kingkiwi's Avatar
I've had my 2.2 since July '05 and it's always been like that. At first I would kinda push it down, but gave up after awhile. Never had any leaks so I can live with it.
Old Mar 1, 2007 | 10:38 AM
RaineMan's Avatar
mine appears to be straight and level...
Old Mar 1, 2007 | 10:44 AM
plyboy-illest's Avatar
yea i noticed that as well...
Old Mar 1, 2007 | 10:48 AM
saunders1986's Avatar
mine moves when i shut the door
Old Mar 1, 2007 | 03:37 PM
haha yea i found out about it when my ex shut the door.. my sunroof moved a little bit.. and i was like "what the ****?"
Old Mar 3, 2007 | 09:01 PM
markmets415's Avatar
Yep my did that too, then wouldn't open and had it replaced (frame) and now the damn thing is leaking. UGH!!!!!!!!!!!!!
Old Mar 3, 2007 | 09:11 PM
RedSSBaltSC's Avatar
It moves because the air pressure in the car forces it to when you close the door, which is why on some vettes (not sure which years) the window stayed cracked about an inch until the door was closed. It was able to let out the air pressure without a problem when closing the door.
Old Mar 4, 2007 | 12:38 AM
iLLmaTic3s's Avatar
word to that. its gonna happen.
Jan 12, 2016 12:01 AM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
