Sunroof rattle
Old Feb 28, 2006 | 09:56 PM
PlaysWitCars's Avatar
Former Cobalt Owner
Sunroof rattle
Does any one else's sun roof rattle?? Mine doesnt do it all the time tho. Like its fine when i go to work but on my way home it sounds like its going to rattle off. I took it to the dealer to check it out and they couldnt reproduce the problem they said. Anyone have any ideas?
Old Feb 28, 2006 | 09:59 PM
MarcS's Avatar
The Stig
Mine rattles in the cold. The sunroof motor is also very sluggish in the cold.
I have rattles all through my dash too.
Old Feb 28, 2006 | 10:01 PM
p7x's Avatar
p7x
same when it gets cold alot things rattle for me
also try lubricating all ur rubber around the sunroof
Old Feb 28, 2006 | 10:08 PM
sethallen's Avatar
i hear ya... i have a damn ratsqueak coming from the rear driver's side of the interior after every bump, and i hear a rattle right above my head closer to the top of the door... it pisses me off!!!
Old Feb 28, 2006 | 10:11 PM
bredick's Avatar
Mine doesn't open, does that count?
Old Feb 28, 2006 | 10:13 PM
alleycat58's Avatar
There's a TSB for the rear suspension on the 06s for a squeak, might be that rather than the interior.
Old Feb 28, 2006 | 10:14 PM
alleycat58's Avatar
Ditto. Ditto. And ditto...
Old Feb 28, 2006 | 11:04 PM
cashstacker's Avatar
My glove compartment rattles and right behind the driver door rattles occasionally. My sunroofs motor has burnt out and I have used it mabey three times in the month I've owned it.
Old Feb 28, 2006 | 11:13 PM
trent_ky's Avatar
YES! Me too!! Do you have sunroof or side airbags? I have both and I am thinking it comes from one of the two.
Old Feb 28, 2006 | 11:16 PM
detrini's Avatar
my sunroof rattled, but you could move it with your hand when it was closed... They replaced the whole thing, in doing so the runined my headliner and then replaced that too. Then the car went into self destruct mode shortly after so I drive rentals now while my dealership practices breaking **** on my car.
Old Mar 1, 2006 | 12:28 AM
cavy-to-SS's Avatar
my sunroof starts to rattle at a speed of 110 plus
Old Mar 1, 2006 | 08:36 AM
Former Cobalt Owner
yeah the sunroof rattle gets freaking annoying. glad to see im not the only one
Old Mar 1, 2006 | 07:31 PM
PenguinPIE's Avatar
did replacing it solve the problem? my dealer asked me if i want to get it replaced but i dont think its gonna go away even with a new one..... i dont wanna waste GM's money
Old Mar 1, 2006 | 07:56 PM
bluecobaltss06's Avatar
yo i have the same problem, all you have to do is open your sun roof, and then they have weather strip lubricant, and you put that on the weatherstripping around the sun roof, and it should go away, mine did
Old Mar 1, 2006 | 08:02 PM
EricTF28's Avatar
Sure wish my dealership was something like yours. Going to my local dealership is like going to the Special Olympics. I told them about my sunroof rattle -- like cavy-to-SS, my problem doesn't show itself until I reach speeds around 100+. Once I mentioned that, all they had for me was a lecture about going that fast, rather than a solution. I'm gonna head up to the town just north of me and see what their dealership can offer me.
Old Mar 2, 2006 | 02:22 PM
Nightcrawler's Avatar
Same here. Keep that rubber lubbed! This happend be because a harder rubber chosen to be used. This is not a 'problem'. You should be lubbing all the rubber on your car anyway. It seems you need to lube every 6 months to keep it sounding completely quiet. i'm sure temperature and enviroment affects this time period as well.
Many cars with sunroofs have the exact same issue.
Old Mar 2, 2006 | 08:39 PM
PenguinPIE's Avatar
but its more like a rattle.....sounds like its knocking on something....and i can move the sun roof up and down on one side by hand.....but not the other side............something is definitely loose up there but the dealer couldnt find it........anyways....what kind of lub should i try on the rubber?
Old Mar 3, 2006 | 02:06 AM
leviticus88's Avatar
Well, if all else fails. Turn the music up! lol
Old Mar 3, 2006 | 02:15 AM
detrini's Avatar
that is exactly what mine did, it was a bent frame... They replaced it and it fixed the problem, but they also ruined the headliner and I could hear something else rattling when they were done.... They are fixing all that now while they are trying to fix all my other problems.. So by monday hopefully my car is better than new... I plan on trading it in at the end of may.
Old Mar 3, 2006 | 08:19 AM
oaklandmr's Avatar
What kind of lube should we be using...mine squeaks a little but not to bad. I dont want the rubber drying out and cracking so I end up with a leak either.
Old Mar 3, 2006 | 08:53 AM
LSpower05's Avatar
Mines doing the same thing. I hopped out and checked all the screws and everything to make sure they were tight, and I couldn't find anything. It happened for the first time yesterday and it was in the 70's so it couldn't be the cold for me.
Old Mar 3, 2006 | 06:28 PM
PenguinPIE's Avatar
i dont wanna hear that rattle anymore....i think im gonna super glue the sunroof tomorrow
Old Mar 3, 2006 | 06:37 PM
mkulrey13's Avatar
mine does all the time. They replaced something inside and its gone. Some peaice came loose. have them take apart the headliner. and look.
Old Mar 3, 2006 | 06:38 PM
Hot Carls R/T's Avatar
My roof shattered when driving at 50km/h...came up like a bubble...At first Gm wasn't paying for it but after we went throught a arbourtrator they fixed it under warrenty the cost $2560.00 for the sunroof/repainting the scratches on the car.
Old Mar 3, 2006 | 10:12 PM
detrini's Avatar
I wedged a piece of paper in mine before I took it to get it fixed... Got rid of the rattle...
