Sunroof uneven outside?
Old 01-10-2011, 09:54 PM
JAYNO20's Avatar
The drivers side of my sunroof sits up about 1/4th of an inch higher than the passenger side. I am getting a lot of wind noise inside due to this I assume... What would I need to do to fix this?
Old 01-10-2011, 10:00 PM
MastaShaKe_88's Avatar
I think.....
I think.. you should jus realize you got a cobalt, an **** fucccs up lol
My driver side window can go up an down almost twice by the time my passenger side does it once, I've replaced my door handles like 7 times, none of my body panels line up right, I gashed my finger last time takin my P/S headlight off with gloves an slid my D/S out with no problem, all my boys dog my car till they ride in it, an all the females say.. "o... well its cute" lol
sht happens..
Old 01-10-2011, 10:04 PM
BlueStang's Avatar
Yep, it's a Cobalt. Get use to it
Old 01-10-2011, 10:07 PM
JAYNO20's Avatar
So... Are there gonna be any helpful posts? I had a supercharged one before and never had an issue with it so obviously it needs readjusted or something. I was just wondering if anyone else had any issues similar. I don't really need to hear about it being a Cobalt.
Gremlin85's Avatar
The weather molding trim on my sunroof is uneven...
Besides the drivetrain, suspension and some emblems... it's still a Cobalt and built cheap like the rest...
That's not to say it could be tweaked/fixed to sit right. I'm sure there are write-ups somewhere on general sunroof adjustments.
Old 01-10-2011, 10:10 PM
JAYNO20's Avatar
Now we are getting somewhere... Write ups work, I am trying to see if I have any bumper to bumper left to see if I can get this fixed by someone else.
Old 01-10-2011, 10:11 PM
BlueStang's Avatar
Yes I had problems with the sun roof on my 08 Sport. It was at the dealer 3 times for fixes and adjustment under warrenty, but I no longer have it so it's someone elses problem
Old 01-10-2011, 10:12 PM
Dr.Balt407's Avatar
if you have warranty just take it to the dealer.
Old 01-10-2011, 10:13 PM
JAYNO20's Avatar
Well it works, just isn't sitting straight so there is more wind noise than there should be.
Old 01-10-2011, 10:17 PM
BlueStang's Avatar
That was one of the problems I had with mine it was uneven on the front drivers side of it
Then when opening and closing it it made a grinding noise
another issue was when closing it at about 98% it would struggle to completly close
Old 01-10-2011, 10:19 PM
JAYNO20's Avatar
No struggle, it seems to close/open just fine... Just wind noise that sucks...
Old 01-10-2011, 10:22 PM
BlueStang's Avatar
Well with mine it started out sitting uneven, then the rest happened later on. But I was covered by the bumper to bumper warrenty, so it just cost me some days of wasted time when it was at the dealership
Old 01-10-2011, 10:28 PM
JAYNO20's Avatar
So they fixed it?
Old 01-10-2011, 10:34 PM
BlueStang's Avatar
They say they fixed it all three times for free and after the third time about two months after they as they said did more adjustments to it the grinding noises came back, but I got rid of the car because it had way too many issues with it other than the sun roof and bought a new pick up truck
Old 01-10-2011, 11:01 PM
JAYNO20's Avatar
Is there any way of checking how long I have left with my GM warranty online?
Old 01-10-2011, 11:04 PM
Acey's Avatar
I don't think you can unless you're an employee. So glad my previous owner made the wise decision of ordering an SS without a sunroof or On-star.
Old 01-11-2011, 08:37 PM
BlueStang's Avatar
In Canada the bumper to bumper warrenty is 3 years or 60 thousand Km which ever comes first, and in the US it is 3 years or 36 thousand miles which ever comes first, so if your over one of those then its not covered
Old 01-11-2011, 08:39 PM
ctn2mb's Avatar
btw... i had this and the dealer replaced it under warranty.
Old 01-11-2011, 08:42 PM
emiller's Avatar
You can get it adjusted or do it yourself if you want to poke around a little. It might be a 2 person job. 1 to sit inside and adjust and someone to stand outside and tell you its even.
Mine needed it when it was new. Its been fine since.
Old 01-12-2011, 01:01 AM
JAYNO20's Avatar
Good info, anyone know what kind of screw driver I'd need to adjust it?
Old 01-12-2011, 04:38 AM
06SS ALL DAY's Avatar
if your getting wind noise its probably because you didnt close the jawn that sits below the sun roof... if my sunroof isnt open i have it closed with that other thing i cannot give a name for it. so its just that jawwwwwwn for now until someone gets me that name. haha
Old 01-12-2011, 12:59 PM
HaVe's Avatar
Search function is key
https://www.cobaltss.net/forums/gene...screws-142126/
I had the same problem. But because weed in Canada in almost legal, my dealer told me that my sunroof is supposed to sit at an angle, it provides downforce.
Old 01-12-2011, 02:08 PM
DaBuzzard's Avatar
That would be the sunshade. And yes, it does cut the noise from the sunroof.....a bit
Angle it all the way up for roadracing
Old 01-13-2011, 03:53 PM
JAYNO20's Avatar
What is being showed in that illustration in that thread? I have no clue what it is saying to do.
Old 01-13-2011, 04:09 PM
68Vette's Avatar
It's nothing to take out our sun roof, 4-hexscrews - Two in front and two in the back. You might want to loosen the hexes screws on the driver’s side and have someone push down gently while you re-tighten the hex screws. You can also heat up a little bit of petroleum jelly and use a rag to put it on the rubber seal as it might help it sit in better. Hope it helps.
Quick Reply: Sunroof uneven outside?
