Surge idle and p0300 random misfire
Ok guys so I'm new to the cobalt community, I picked up a 2006 cobalt ss/sc for 2000 dollars
Following mods:
Zzp long tube intake
Zzp 3.0 pulley
Zzp #42 injectors
Zzp dual pass end plate
Zzp cel down pipe
Zzp shorty header
Sickspeed oil catch can
Upgraded radiator
NGK iradium spark plugs
Custom HPtuner
Full magna flow CBE
GM stage 2
Ported polished supercharger
Otp front mount heat exchanger
But here is the issues I am having so far.
PROBLEM ONE
On cold start it surges idle. I've looked all over for a vacuum leak, and I can't find one
I've thoroughly cleaned the Tb twice (even used a damn toothbrush on butterfly joints)
Cleaned the MAF
removed and cleaned the injectors and checked o rings
PROBLEM TWO
Misfires at idle. Throws a random misfire code. If I reset the ecu by unplugging the batter than it will clear the code and not return for a day or so.
But the surge idle is getting way worse. The car will stall out randomly at idle.
I have a wideband that is reading 19.1 AFR to 13.6 it jumps back and forth. I'm not sure if I can trust the wideband because I'm not getting white smoke, and I'm actually getting black smoke(once I hit rev limit) and it smells a bit rich.
I changed the spark plugs recently and no help. I also checked the timing chain thinking it jumped a tooth or possibly a bad timing chain tensioner, but it was good also.
I'm clueless guys.
Following mods:
Zzp 3.0 pulley
Zzp #42 injectors
Zzp cel down pipe
Zzp shorty header
Upgraded radiator
Custom HPtuner
Full magna flow CBE
GM stage 2
PROBLEM ONE
Cleaned the MAF
PROBLEM TWO
I'm clueless guys.
Following mods:
Zzp 3.0 pulley
Zzp #42 injectors
Zzp cel down pipe
Zzp shorty header
Upgraded radiator
Custom HPtuner
Full magna flow CBE
GM stage 2
PROBLEM ONE
Cleaned the MAF
PROBLEM TWO
I'm clueless guys.
Following mods:
Zzp 3.0 pulley
Zzp #42 injectors
Zzp cel down pipe
Zzp shorty header
Upgraded radiator
Custom HPtuner
Full magna flow CBE
GM stage 2
PROBLEM ONE
Cleaned the MAF
PROBLEM TWO
I'm clueless guys.
Getaway_Driver
Sep 19, 2015 09:39 PM
