Suspension clunk: response from GM
Old Dec 18, 2006 | 06:44 PM
red_wing_2121's Avatar
This is the response I got from GM about my front suspension clunk. I should hear more on Friday, as the message states:
Service Request: 0000000000000
Customer Relationship Specialist: Melissa Dziedzic
Dear Mr.Stepke,
We sincerely apologize for the concern you are experiencing with your
2005 Chevrolet Colbalt
We have documented your comments with the Customer Assistance Center
under request number 0000000000 and are investigating your concern. We
will follow-up with you on December 22 2006 at 12pm Eastern Standard
Time with an update.
If you have any further information or comments, please contact us
using the information provided below.
If you should need to contact us in the future, simply reply to this
message or call our Chevrolet Customer Assistance Center at
1-800-462-8782. Customer Relationship Specialists are available Monday through
Friday from 8:00 a.m. to 11:00 p.m., Eastern Time.
For more information regarding the maintenance and care of your
vehicle, please visit www.mygmlink.com. This free online service offers
vehicle and ownership-related information and tools tailored to your
specific Chevrolet.
Again, thank you for contacting Chevrolet.
Sincerely,
Melissa Dziedzic
The Chevrolet Consumer Support Team
Will keep you updated as information becomes available.
Edit: Yes, a person from GM actually spelled Cobalt wrong.
Old Dec 18, 2006 | 06:47 PM
sethallen's Avatar
what side is it coming from? and does it happen only when u hit a bump?
i may have the same thing
Old Dec 18, 2006 | 06:50 PM
keeper51's Avatar
I've been having the same problem for a few months now. So far they have replaced my steering column links cause they said they were loose. then a month after that i brought it in and they said I had a broken strut so they replaced that and did an allignment. Now 2 weeks after that i'm having the same problem and I think it's actually worse this time, please keep us updated
Blue_ghost's Avatar
How loud is the clunk and when does it happen? I have a small clunk on the left front going over small bumps that should not cause a clunk. Almost sounds like a brake caliper is a tad loose. Please paste the link if there is one...I am @ work and do not have time to search.
Old Dec 18, 2006 | 06:52 PM
sethallen's Avatar
blue that is the exact sound i have
The clunk seems to come from the RF. It is very noticeable and almost sounds like the strut mount nuts are loose, but they are not.
All suspension components are tight and my intermediate shaft has already been replaced once, yet the clunk continues.
Old Dec 18, 2006 | 07:01 PM
keeper51's Avatar
I also have the clunk going over small bumps but I think more so on the right side, and I'm not sure if anyone else will agree but the feeling u kinda get through the steering column is sorta along the same lines of that lil pulsing sensation u get when the ABS kicks in???? but only going slow i'd say between 0-40km/h
Old Dec 18, 2006 | 08:22 PM
Yeah, I think that is pretty much what I have.
Keep checking this thread for updates!
Old Dec 18, 2006 | 08:36 PM
calchr2's Avatar
does the noise/clunk happen when you drive around turns? especially in one direction or both? it might be loose sway bar end links. try looking at those and see. youd have to raise the car off the ground to see if they are loose. however if they are really loose they will have more and just a little movement when the wheels are on the ground. take a look.
Old Dec 18, 2006 | 09:12 PM
I checked everything before I took it in to the dealer. All suspension is tight.
Old Dec 18, 2006 | 09:19 PM
NJCOBALTSS's Avatar
i have a similar noise also in the rf it makes a clunk sounds like a strut or something and also happens when you hit the gas for a millasec. it makes the noise when you hit it then makes the noise when i let off, the only problem is it goes away when the car gets warmed up, by the time i get to the dealer its gone, and doesnt come back the rest of the day until the morning.
Old Dec 18, 2006 | 09:33 PM
yellowcobaltss05's Avatar
i have the same problem on the front/right suspension...when i had my car on a lift i looked around and found out that my sway bar was grinding down my control arm. I have been in an accident before but it still made the same sound before the accident.
Old Dec 19, 2006 | 07:03 AM
I will have to check that out.
Old Dec 19, 2006 | 10:17 AM
07cobaltss's Avatar
alot of times the bearing is seated worng, or just be plain bad and can make a clunk, is it when your turn your wheel, or just go over bumps?
Old Dec 19, 2006 | 10:40 AM
mine is just from hitting little bumps in the road and speed bumps. Still our cars should not make noises like this. I had GM fix it (or at least they said they fixed the clunking noise) but sure enough it was still there
Old Dec 21, 2006 | 06:11 AM
keeper51's Avatar
Well I called my dealership and told them i'm having the same problem, 3rd time now, that there might be a TSB for it possibly and they very rudely said "if there was a TSB we'd know about it and out of every cobalt we've sold urs is the only one were having problems with". What a bunch of BS. So i'm taking my car in on the 27th and they are giving me a loaner so they can have a look over it, in the meantime i've got some calls in to a few contacts in GM to see if they know anything about it. Anybody else have any updates on their car, solutions?
Old Dec 28, 2006 | 11:47 PM
keeper51's Avatar
anybody have any luck on this matter yet?
Old Dec 29, 2006 | 12:07 AM
Blown 4-banger's Avatar
I ALSO have a clunking noise! I can feel it in the steering wheel, like when going over small bumps or driving on a rough patch of road! I don't know what it is, but I'm scared the wheel is gonna fall off or something!!!
Old Dec 29, 2006 | 01:01 AM
Xavipheus's Avatar
I just seem to be having alot of noise going over bumps. SO much for quiet ride steel or w/e bullshit the sales guy pitched at me. Anyways, I had my internal steering shaft replaced and ive been going to GM alot lately for fixes, im afraid the SM is gonna get sick of hearing me complain. Does anyone know if theres a TSB out yet for the suspension or something? I'm sick of this problem but I don't wanna bring it in and have them say theres no problem.
Old Dec 29, 2006 | 01:14 AM
JapEatr's Avatar
South Central *********
there is a TSB on the intermediate shaft of the steering column
i had mine replaced today, now im not hearing the clunk as much
alignment is now off tho
bastards didnt even set my toe, steering wheel is 3odegrees off , ill fix it this weekend at work when i do my CABs
the TSB and part # are on the service report, ill take a look at it tom.
PM me if i forget
They also drilled a hole in my firewall, cuz the stud that is spotwelded to the body that holds the shift cable broke off and was rattling on the exhaust, and causeing 4th to be real sloppy do to the play in it
so they put a bolt through, but i hear wicked exhaust noises through the hole
its loud, stereo overpowering noise cuz they cut the sound dampenening and the carpet to get to the hole
Old Dec 29, 2006 | 01:22 AM
Is this part of the extended warrenty or just the basic warrenty for factroy defects? I'm wondering because I don't think I have an extended warrenty anymore, and don't want to pay $300,000 to have my car looked at.
Old Dec 29, 2006 | 01:24 AM
JapEatr's Avatar
warranty TSBs are just that, i printed off the bulliten from the mitchell guide at work
took it to the dealer and told them whats up
they did it no questions asked, i was really nice tho
Old Dec 29, 2006 | 01:28 AM
So all I have to do is print off some TSB thing and the dealer will do it no questions asked? Even if I traded in my extended warrenty? Is there a link to the TSB so I can print it off?
Old Dec 29, 2006 | 01:33 AM
JapEatr's Avatar
i got it off a service guide at the shop im working at
see if one of the google searches show up TSBs and recalls(make sure it has all current TSBs b4 ya pay to access them)
the dealer will usually honor a warranty b4 the 30K mark without problems
also my case is different as they had my car for 95 days previously and now they have given me payments back and a new warranty im going to trade my other warranty in ASAP to have mod money(since i have dual policys)
Old Dec 29, 2006 | 04:09 AM
Roadrunner's Avatar
I have something simmilar to you all, but i have a crappy 05 LS?!?!
Edit: Has anyone heard of this problem on the 06's and 07's?
