Sway Bar End Link Nut
Hello,
Does anyone know the specs of the sway bar end link nuts?
I derped and accidentally zipped it onto the strut-->knuckle bolt, rendering both useless. Both nuts have the same 18mm hex and the same diameter, but the end link nut is a finer thread.
Replaced the strut-->knuckle bolts no problem, but will need to make a run to the hardware store for the sway bar end link nut.
I'll bring a knuckle bolt and get something finer of the same diameter if nobody knows offhand.
Thanks
Edit: Just realized I can use the other side's nut for reference. I'm not thinking today.
Thanks
