Synthetic Oil question
Old Mar 28, 2006 | 11:37 PM
HiSpdPursuit's Avatar
kinda pains me asking questions about oil since i am pretty adept mechanically, but. I have a brand new Pontiac Pursuit and it is my first NEW car...so first time for me doing an engine break in (had a 88 5.0 mustang before.) will the dino oil have done its job of breaking the engine in by the time it comes to do the first oil change?
my question is will the dealer do a full synthetic oil change for me for the 1st oil change and will it affect the warranty at all?? also when i am buying FULL synthetic oil how do i know its really FULL synthetic as opposed to the oils that call themselves synthetic but are really petroleum and synthetic blends
Old Mar 28, 2006 | 11:45 PM
avro206's Avatar
First oil change should be okay. I swithced mine at the 2nd but may have been paranoid
Any oil going into your engine must meet GM Standard GM6094M. Look for that on the bottle.
Warranty will be fine switching oil.
Mobil 1, Amsoil and Castrol syntec, Castol Syntec blend (semi-synthetic) meet this standard.
I have heard things about Castrol about not quite being a treu synthetic.....but Mobil 1 and Amsoil are.
Old Mar 29, 2006 | 12:00 AM
jokieman's Avatar
Mobil 1 is what everyone I know uses.
Old Mar 29, 2006 | 12:08 AM
leviticus88's Avatar
Mobil 1 all the way!
Old Jul 9, 2006 | 10:26 PM
R&C_rallySS's Avatar
Oil
Amsoil seems to have the best effect on my Cobalt SS/SC. I have a dealer down the street from my house and it's been running strong.
Old Jul 9, 2006 | 10:34 PM
g5mike's Avatar
My GT is lovin the Mobil 1
Old Jul 9, 2006 | 10:37 PM
kissmySS's Avatar
Ill share the limited knowledge i have on this topic... You guys are correct Mobil 1 is a true synthetic, any other oils are a synthetic "blend" there is a certain percentage a company must have to call it synthetic, When the oil was first released it was so expensive to make so the "other" companies switched to a synthetic blend because there was just really no market for it too much money etc... Mobil OR Chevron Texaco/Havoline (canadian) decided to keep there full blends and found another cheaper way to refine it and sell it, So in short MOBIL 1 and Havoline(only available in canada) MEET GM SPECS for synthetic, I have researched this and have decided that i will be switching my oil to Havoline (not to be confused with Valvoline) due to the fact i can get in 3 dollars cheaper a liter because my good buddy works for Texaco..! Hope this helps any other questions feel free to ask and i will pass the questions on to him for an answer..!!
Old Jul 11, 2006 | 06:25 PM
My06Kobalt's Avatar
ROYAL PURPLE all the way. nothing compares. nothing.
Old Jul 11, 2006 | 06:30 PM
kissmySS's Avatar
Old Jul 11, 2006 | 06:57 PM
zomghax's Avatar
Mobil 1. I switched at like maybe 2k. If my car blows up in a few years you can all point and laugh then.
Old Jul 11, 2006 | 09:45 PM
Coblasts's Avatar
Check out Crap-Tires formula 1
I checked Canadian tires formala 1 synthetic and it meets the gm 7418 standard which is stated in the manual for ths SS-SC and the Corrvette.
I also got on sale for $19.99 on sale for 4.4 liters ,reg.$28.00 approxVerses 38.00 for
Mobil 1
Old Jul 11, 2006 | 09:49 PM
AZCobalt19's Avatar
Sort of off topic, but when is a good and useful time to change the oil on my 2.2? Had since march, and it has 3100 miles? DIC says the oil life is 55% but I hear that its good to change it twice as often?
Any help greatly appreciated..
Old Jul 11, 2006 | 09:54 PM
avro206's Avatar
my first was changed at 5000kms---thats about 3K miles. I only did it early bbecause it was the first.
Old Jul 11, 2006 | 10:06 PM
AZCobalt19's Avatar
Is there any advantage to that, or is it just a safe way to go?
Old Jul 11, 2006 | 10:08 PM
Coblasts's Avatar
Cut open the filter and check it out
I did my first change at 2500 kms and cut the end off the filter just to see and was quite
surprised at the size of aluminum chips trapped in it.
Made me feel better to change it early incase there was more floating around in there and not getting to the filter.
Old Jul 11, 2006 | 10:19 PM
avro206's Avatar
no--just safe. There are some that change it much earlier on the first but to me thats old school thinking. If you really had to change it very early---GM would say so
Old Jul 12, 2006 | 06:52 AM
High_PSI's Avatar
Mobil 1 is excellent and since it's actually printed on the oil cap of the SS/SC models, you can't go wrong. IMHO, Amsoil is the absolute best on the market, however you are only splitting hairs at that point because they are both so superior to most other oils. I will say that the only down side to running Amsoil is that the independent dealers (jobbers as they are called) can be hard to find depending on where you live. Also, Amsoil (Hastings) filters are one of the best on the market if you are also debating on which filter brand to go with. Again, this is just from experience and views expressed in this post are opinion only, and we all know the old saying about opinions! Good Luck.
Old Jul 12, 2006 | 08:49 AM
Kahless's Avatar
no, with all the detergents and additives in oil these days most times you can go 6000-7500 miles before changing your oil. thats with mostly highway miles tho. if youre in alot of start n stop or you hotrod it 3000-3500 is still safer. i used to "change" it every 3000 miles but after i realized it needed it and finally got to changin it it would be closer to 4.
Old Jul 12, 2006 | 09:26 AM
roccobladr's Avatar
i plan on changing my oil soon and i wanna go synthetic. im only at about 400 miles right now though. how long should i wait before going to synthetic. i have the 2.4ss if it matters.
Old Jul 12, 2006 | 10:00 AM
06G5GT's Avatar
Here's a link for an Amsoil vs Mobil 1 test. A real test too, not something paid for by Amsoil on their websites.
http://neptune.spacebears.com/cars/s.../oil-life.html
Take a look at what starts happening to Amsoil at the 12k mark.
Bottom line. Both are very good oils. One claims really long change intervals. This test proves that's not safe to do.
Old Jul 12, 2006 | 12:20 PM
AZCobalt19's Avatar
Thanks for all the info.. I think im gonna change mine out here this week.. so ill be right around the 3200 mile mark..
Definately going to go with the mobil 1 oil...
Old Jul 12, 2006 | 05:38 PM
My06Kobalt's Avatar
i do mine every 2500 miles on the dot with the Royal Purple Synthetic. I'm just makin' sure my engine will run forever.
Old Jul 12, 2006 | 05:39 PM
My06Kobalt's Avatar
i used to use Mobil-1 and never had a problem they're my second choice for sure.
Old Jul 12, 2006 | 06:04 PM
06G5GT's Avatar
If that's the case, you need to revise your thinking. Engine oil with a thousand miles protects better than brand new oil. Hard to believe but it's been proven with oil analysis samples of wear particles.
Old Jul 12, 2006 | 06:15 PM
Novajoe's Avatar
anytime you take your new car into the dealer they put synthetic in it for warranty purposes. Synthetic is always the better way to go because it takes longer to break down in your motor. The only time I would not recommend using it is on older cars. Synthetic tends to find leaks in seals and such much easier than ur regular petrolium oil
