TB Alignment Help
Old Jun 25, 2008 | 05:38 PM
Altiery54's Avatar
TB Alignment Help
Is my TB suppose to have gaps like this???? i am not touching the plate at all, and its like semi open. help!!!
bump it
Old Jun 25, 2008 | 05:39 PM
invisible's Avatar
**** man, I thought mine was closed all the way but if you don't get an answer, when I get home, I will pull mine off and let you know.
Old Jun 25, 2008 | 05:46 PM
Altiery54's Avatar
man i think i would come 2 N.M. to shake ur hand if u did that. this could very well be that damn nagging problem i have if this thing is suppose to be shut
Old Jun 25, 2008 | 05:48 PM
invisible's Avatar
Alright man, I sure will.
Old Jun 25, 2008 | 05:49 PM
DoubleLP's Avatar
I would think that there should be a gap because when the car is at idle you are not touching the gas and opening the throttle body but the engine still needs air to run.
Old Jun 25, 2008 | 05:52 PM
invisible's Avatar
True but it is not running.
I am about 90% positive that mine was closed and when I would force it open and let it go, it would slam shut again.
Old Jun 25, 2008 | 05:56 PM
Stouffer's Avatar
Yeah i jsut had mine off a couple of weeks ago and it would slam shut when I would force it open
Old Jun 25, 2008 | 05:57 PM
Blur.fx's Avatar
Pave It All...
Mine looks like this:
The blade doesn't sit fully shut when it stops, there seems to be a detent holding it off of being completely closed but you still can't see anywhere near as much light as yours has coming through it.
Old Jun 25, 2008 | 06:25 PM
Area47's Avatar
Rent me! per hour
it's fine.
Old Jun 25, 2008 | 09:29 PM
Coblasts's Avatar
The pcm Im sure instructs it to close and sets a zero position for it and the gas pedal when you first turn the key to start the car.This is done to sync the two together.
Found this for you !!
The throttle body functions similar to a conventional throttle body with the following exceptions:
• An electric motor opens and closes the throttle valve.
• The throttle blade is spring loaded in both directions and the default position is slightly open.
• There are 2 individual TP sensors within the throttle body assembly.
The TP sensors are used to determine the throttle plate angle. The TP sensors provide the powertrain control module (PCM) with a signal voltage proportional to throttle plate movement. The TP sensor 1 signal voltage at closed throttle is near the 5-volt reference and decreases as the throttle plate is opened. The TP sensor 2 signal voltage at closed throttle is near the low reference and increases as the throttle plate is opened.
Powertrain Control Module
Old Jun 25, 2008 | 11:37 PM
bridfi's Avatar
i thought everyone knew that?
TotalChaos
Oct 14, 2015 06:49 PM
DANRICKARD
Oct 1, 2015 12:08 AM
CobaltSS 16
Sep 12, 2015 02:43 PM
ROADKONE
Sep 9, 2015 02:32 PM
DisJuan
Sep 7, 2015 04:24 PM
