Thoughts on a problem?
Old Feb 6, 2009 | 11:36 PM
EatonTVS07's Avatar
So i have 2 sets of HID kits for the headlights and the fog lights. The one for the headlights i've had for about 2 years now. well a couple weeks ago i noticed they flickered alot until they eventually didnt turn on. well i looked through and realised the relay had alot of corrosion on it. so i replaced the relay after scrubbing off the relay plug in and we where good to go.
Now last weekend i realise i have a light out on the passenger side. figured i would wait till i had time and it was warm to look into this. well today i realise both where out so i decided to check it out, at first thought the bulb could of been blown checked it out, there good, fuses good, relays good. so i thought maybe it was the ballast.
foglights still work so i hook up the ballast for the fogs to the driver side headlight and look there it works i figured it was the ballast was bad. so i go over to do the same thing on the passenger side get done turn it on and, driver side comes on but he passenger side doesnt. it'll flick on like it wants to then turn off.now the driver side does it to wtf!?!? tried replacing fuses, relays, switch ballasts, nothing i'm truely baffled. good power sources good ground sources, mounted under the headlight housing. any ideas on this? i may try to just rewire the whole damn thing tomorrow if it still dont work will probabaly get rid of the shity kit and order another from 3bspec or somthing. any help would be awesome, even if you have nothing to add i appreciate you taken the long ass time to read all this
Old Feb 6, 2009 | 11:37 PM
car_guy_09's Avatar
They just dont like you....
Old Feb 6, 2009 | 11:41 PM
EatonTVS07's Avatar
seems that way, after i replaced the relay i also noticed a lesser output then what it was and i got the exact same relay
Old Feb 6, 2009 | 11:42 PM
car_guy_09's Avatar
Try a higher amp relay
Old Feb 6, 2009 | 11:43 PM
EatonTVS07's Avatar
no more talking from you junior. lol i should post this on yc and see what kinda answers i get
Old Feb 6, 2009 | 11:44 PM
car_guy_09's Avatar
lol, Srsly, I had that same thing with my fuel pump rewire with a 35amp relay, Went and bought a 40amp and never had anymore problems
Old Feb 6, 2009 | 11:45 PM
EatonTVS07's Avatar
still doesnt tell me why it worked with the same relay before i put the new one on though
Old Feb 6, 2009 | 11:46 PM
car_guy_09's Avatar
No idea...
Electronics are temperamental
Old Feb 6, 2009 | 11:48 PM
sport08's Avatar
lol u should post it on yc there pretty retarded over on that site but yeh this is baffling on y it doesnt work. i say buy a new kit if u have the money and save urself the frustration.
Old Feb 6, 2009 | 11:49 PM
EatonTVS07's Avatar
lets see you figure the amount of corrosion thats still on there increases the resistance, resistanace goes up current goes down, so i dont beleive a higher amp relay will help me on this one, maybe it doesnt have enough current to trip the relay and hold it?
Old Feb 6, 2009 | 11:51 PM
car_guy_09's Avatar
Possible
Old Feb 6, 2009 | 11:52 PM
sport08's Avatar
makes sense cause the corrosion is taking away contact area that closes the circuit so all of the current is trying to got threw less area causing more resistance i say try it.
Old Feb 7, 2009 | 12:27 AM
EatonTVS07's Avatar
perhaps a smaller amp relay then
bump for a thought
Old Feb 7, 2009 | 08:48 AM
Coblasts's Avatar
Resistance goes up you will get a voltage drop across the resistance,and this is what creates issues
If the are flickering put your finger on the relay to see if its buzzing.
If the voltage is to low the ballasts wont start and will flicker relay could do the same if there is not enough voltage to hold the coil in.
Old Feb 7, 2009 | 02:04 PM
EatonTVS07's Avatar
ah yes makes sense i'm an electrical novice should of paid more attention . the ballast does not kick on, so i'll probably need a new harness huh
biniecki
Oct 25, 2015 02:23 PM
cw383
Sep 30, 2015 12:41 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
