A ticking noise in the engine at idle...
Okay soo i installed my k&N intake last night...and now i hear a ticking noise when it is idling when i have the hood open... My friend says it was like that before but me i dont remember it ever doing that... so do any of you 2.4l guys want to just pop the hood and listen to your car idle and tell me if u got a little ticking noise...
does anyone have any idea if it is normal
Last edited by SC cobaltss15; Aug 22, 2007 at 09:13 AM. Reason: Automerged Doublepost
no it does not continue and it isnt a loud ticking...89 octane
does anyone else have this problem?? please check...and i dont think its spark knock....its not that loud its just really faint tick tick tick
Last edited by SC cobaltss15; Aug 22, 2007 at 09:39 AM. Reason: Automerged Doublepost
Original Hayden Fanatic
nooo its a little tick...and i didnt notice it until i put my intake in....will any of u guys gooo check for mee?
thanks
anybody?
thanks
anybody?
Last edited by SC cobaltss15; Aug 22, 2007 at 11:29 AM. Reason: Automerged Doublepost
That is the normal sound of the valvetrain. It is probably louder beacause the big air box on the engine isn't muffling it as much. The cat also makes little ticking noises when the car is running and for a little while after it is off.
Also 89 octane sould be fine. I have tried 89, 91, and 93 gas and monitored the knock sensors with my daskhawk and I have found no difference in my 0-60 times and the engine doesn't register any issues with knock. Every once in a while with 89 I have seen 1 knock out of 100 cycles which can happen with 91. So there might be a slightly higher chance of knock but nothing to worry about.
Yeah normal valvetrain noise. All the cobalts make some noise at idle.
Also putting higher octane gas in your car does nothing at idle... it only matters when you are actually putting the engine under a load when it needs the extra protection from detonation or unless you run like 13:1 compression in the engine.
idk guys
i have that ticking your talking about but now my car is at the dealer bc the when i rev it up the exhuast makes a wicked mean sound for the worst and when i brought it in they asked if i had an oil change recently bc there was oil all over the bottom of my engine,fuel rail, headers everything. but of course they wont fix it...... bc theres no cel
check the neck of it, see if it's wet there.
patooyee
Oct 1, 2015 01:07 PM
DANRICKARD
Oct 1, 2015 12:08 AM
